Tip & How-To about Washing Machines
How to service a lid switch
The lid switch on a washer often serves as a safety switch. If the switch is not working, or if the switch opening in the lid is clogged with detergent, the machine will not run. To check and repair the lid switch:
- Unplug the machine. Clean out the lid switch port with a wood manicure stick or chopstick. Clean off any detergent buildup around the rim of the lid. Sometimes there's enough detergent encrusted on the metal to prevent the lid from closing tightly and keep the washer from operating.
- If cleaning doesn't help, remove the top of the cabinet to get at the switch. With the switch exposed, check the screws for looseness. Loose screws can cause the switch to move when the lid is closed or as the machine goes through its cycles. Check the terminals of the switch to make sure they're tight. Tighten the mounting screws after the switch is in alignment. -Test the switch with a VOM set to the RX1 scale. Disconnect the power leads to the switch terminals and clip one probe of the VOM to each terminal. Close the lid of the washer. If the meter reads zero, the switch is working. If not, the switch is faulty and should be replaced. - If necessary, replace the lid switch with a new one of the same type. Connect the new switch in exactly the same way the old one was connected.
- If the switch still doesn't work, it is probably misaligned. Realign the switch by repositioning the screws holding it in place, testing the switch as you go until it works properly.
Washing Machines Logo
Wont drain
1. Check and make sure that the washer is plugged in. I know that sounds stupid, but washers move and it has happened before.
2. Check and see if the washer works during the rinse cycle. if the motor moves then skip to step 3 If the motor does not turn then you need to test the power outlet. use a small hand held appliance like a hand mixer to make sure the outlet has power. If the outlet has no power you need to check your breakers. If the outlet has power you need to call a repairman for your washer.
3.Good news because your washer works on the rinse cycle your problem may not be that severe. First check to make sure your lid switch is working. The lid switch is a safety device that ensures that the lid is closed before the machine will begin the spin cycle. to check the lid switch simply close and open the lid several times. each time you close the lid you should here a distinctive click. if there is no click then you need to replace the lid switch. if the is a click continue to step 4
4. Ok you have power and you lid switch is working that means you have one of two things going on. 1. you have clog in the line or 2. your pump is burnt out. To check for a clog start at the back of the washer and remove the drain hose. Be ready for water! It may come pouring out. if water does come pouring out then you need to check the drain hose for a clog. If there is no clog in the drain hose then you have a bad pump and it will have to be replaced. If water does not come out when you remove the drain hose then you have a clog. the clog is either in the pump or in the upper hose that runs from the tank to pump.
Nov 20, 2010 | Maytag Washing Machines
Water is now filling, washing going round in drum but not rinsing or spinning.
Spinning and Rinsing require a safety switch to be enabled by the closing of the washers lid.
Check around your lid and washer lid opening to find the mechanism that is used to activate the safety switch mounted just under the lid opening inside your machine. Sometimes it is a plastic plunger(protrusion) on the lid that mates with and opening(hole) in the machine around the lid opening to cause this switch to close. Other times it is on the hinge side of the
lid and the protrusion is formed right into the metal of the lid itself to push a plunger on the hinge side to close this safety switch.
Most spinning problems on machines are cause by this lid safety switch. Washing machines cannot spin if the lid is not closed and this safety switch is not working to switch power to the spinning motor.
Aug 30, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
water doesnt drain
hi friend,
Instructions
  1. Step 1 Check and make sure that the washer is plugged in. I know that sounds stupid, but washers move and it has happened before.
  2. Step 2 Check and see if the washer works during the rinse cycle. if the motor moves then skip to step 3 If the motor does not turn then you need to test the power outlet. use a small hand held appliance like a hand mixer to make sure the outlet has power. If the outlet has no power you need to check your breakers. If the outlet has power you need to call a repairman for your washer.
  3. Step 3 Good news because your washer works on the rinse cycle your problem may not be that severe. First check to make sure your lid switch is working. The lid switch is a safety device that ensures that the lid is closed before the machine will begin the spin cycle. to check the lid switch simply close and open the lid several times. each time you close the lid you should here a distinctive click. if there is no click then you need to replace the lid switch. if the is a click continue to step 4
  4. Step 4 Ok you have power and you lid switch is working that means you have one of two things going on. 1. you have clog in the line or 2. your pump is burnt out. To check for a clog start at the back of the washer and remove the drain hose. Be ready for water! It may come pouring out. if water does come pouring out then you need to check the drain hose for a clog. If there is no clog in the drain hose then you have a bad pump and it will have to be replaced. If water does not come out when you remove the drain hose then you have a clog. the clog is either in the pump or in the upper hose that runs from the tank to pump.
Tips & Warnings
  • make sure to unplug the washer before disassembling. water and electricity don't play well together
thank u for using fixya
regards,
sivaranjini
Aug 12, 2009 | GE Energy Star WCVH6260F Front Load Washer
Power comes on but nothing happens
hi
Step 1: Unplug the machine. Clean out the lid switch port with a wood manicure stick or chopstick. Clean off any detergent buildup around the rim of the lid. Sometimes there's enough detergent encrusted on the metal to prevent the lid from closing tightly and keep the washer from operating.
Step 2: If cleaning doesn't help, remove the top of the cabinet to get at the switch. With the switch exposed, check the screws for looseness. Loose screws can cause the switch to move when the lid is closed or as the machine goes through its cycles. Check the terminals of the switch to make sure they're tight. Tighten the mounting screws after the switch is in alignment.
Step 3: Test the switch with a VOM set to the RX1 scale; procedures for using the VOM are detailed
here. Disconnect the power leads to the switch terminals and clip one probe of the VOM to each terminal. Close the lid of the washer. If the meter reads zero, the switch is working. If not, the switch is faulty and should be replaced.
Step 4: If necessary, replace the lid switch with a new one of the same type. Connect the new switch in exactly the same way the old one was connected.
Step 5: If the switch still doesn't work, it is probably misaligned. Realign the switch by repositioning the screws holding it in place, testing the switch as you go until it works properly.
Nov 21, 2008 | Washing Machines
matsui mf160 deturgnt door wont open
hi The lid switch on a washer often serves as a safety switch. If the switch is not working, or if the switch opening in the lid is clogged with detergent the door will not open
Sep 13, 2008 | Dishwashers
205 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
