Tip & How-To about Plumbing
Ball-Type Single Lever Faucets
BALL-TYPE SINGLE-LEVER FAUCETS
  • The single-handle faucet with a ball inside to control both hot and cold water may either leak at the spigot or at the handle. A handle leak is usually caused by improper adjusting-ring tension. Simply adjust the tension to stop the leak. Leaks at the handle can also result from a worn cam gasket. Dripping from the spigot is usually caused by worn spring-loaded, soft rubber seat assemblies.
  • Parts for ball-type faucets are available in kits. Get the spring/seats kit for spigot leaks, or the complete kit for handle leaks. It may be advisable to use the complete kit to replace all working parts of the faucet at the same time. In any case, you'll need a kit containing the spanner/hex wrench for removing the handle (hex end) and turning the adjusting ring (spanner end).
  • Without turning the water off, loosen the handle set screw. Slide the handle from its stem.
  • For a handle leak, try using the spanner wrench to tighten the adjusting collar. Tighten it by turning the wrench and collar clockwise until the faucet doesn't leak when it is turned on and off. If the adjustment is too loose, the faucet will leak. If you turn it too tight, the handle will be hard to move. When the adjusting ring cannot be turned with the wrench, it is corroded. At this point, you will need to remove the cap to free the adjusting ring. (See next step.) You must turn the water off before removing the cap! Apply penetrating oil to the threads, remove the ring and clean all parts before reassembling.
  • Install the seats. For faucet leaks at the spigot, you must install new rubber seats and springs. You must turn off the water to make this repair. Unscrew the chrome cap by turning it counterclockwise. If it won't turn easily, wrap electrical tape around the cap and turn it with pliers. The adjusting ring, which is threaded into the cap's center, will come off with it. For a seats/springs replacement, pull the ball up and out by its stem. The gasketed cam will come with it. Now you can locate the two rubber seats and springs inside the faucet body. Remove them with pliers or yours fingers and install the new ones. The springs go into the holes first, and the cupped sides of the seats fit over the springs.
  • Service the ball. If the ball is dirty or coated with scale, clean it or replace it with a new one. Both plastic and brass balls are available, but use a plastic one if your home has hard water.
  • Reassembly. Put the ball and cam back into the faucet with the slot in the side if the ball fitting over the pin in the faucet body. Then make sure the tab on the cam slips down into the notch in the body. Not aligning the tab and notch is the number one cause for a faucet leaking after it is repaired. Finally, screw on the cap and adjust the ring as described in Step 2. If a properly adjusted ball-type faucet leaks at the cap, the cam and gasket must be replaced.
  • Swing spouts. If a single-lever ball faucet leaks at the base, you should replace the O-rings. Remove the spout-retaining parts, as well as the spout. Wrap the spout-retaining nut with electrical tape to protect it, and remove the nut with a wrench or pliers by turning counterclockwise. Remove the spout by pulling it up and side-to-side. One or more O-rings should now be exposed. Take the O-rings to your hardware or home center store to get matching O-rings for replacement. Clean any scale that appears on the spout base, faucet body, and the inside of the swinging spout. Install the new O-rings and reverse the steps above to reassemble the faucet.
Plumbing Logo
kitchen faucet
you have to tell me more is it single lever or hot and cold hot and cold have stems with rubber washers in end they are held in place with a crown nut ( big as half dollar) FIRST AND FOREMOST TURN THE WATER OFF AT THE BASE THIS GOES FOR HOT AND COLD I if you have a single lever faucet you have to remove the handle( also true for hot and cold faucets) after the handle is removed on single lever you have some type of crown ( looks like a rocket nose cones ) usually it is screwed on and holds some type of cartridge or ball anyway you use a wrench called a channel lock or vice grip to take apart i need more info before i can tell you more
Aug 27, 2014 | Plumbing
getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
Apr 25, 2010 | Delta Model 172: Waterfall Single Handle...
Moen kitchen faucet. I changed the cartridge but
Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Nov 12, 2008 | Kohler Forte entertainment remote valve...
619 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
