Tip & How-To about Plumbing
How to repair a noisy faucet
REPAIRING A NOISY FAUCET
  • A noisy washer-type faucet is usually caused by a loose seat washer. To stop the noise, first turn off the water and take the faucet apart as described previously. If the washer is loose, tighten it or replace it.
  • After threading the stem back into the faucet body, try moving it up and down. If it moves, the stem is worn and the entire faucet must be replaced.
  • Some faucets are noisy due to poor design and construction. The only way to solve this problem is to replace the faucet with a quality one
Plumbing Logo
how do i stop a slow drip in a tub faucet?
A drip is caused by seepage from the water supply. Remember the water supply enters your home under pressure, so there must be a watertight seal holding back the incoming water when the faucet handle is in the OFF position. That seal is usually created by a washer pressed tightly against the faucet seat. Obviously, when the washer or the seat is not functioning properly, a little water can seep through and drip out of the faucet spout. To stop the drip, all you usually have to do is replace the washer or repair the seat.
Jun 01, 2012 | Home
noisy faucet
Possible block on the line and if you can use a pressure washer to flush it can help to drain the dirt within that seems to cause the noise from the obstruction of the water flow. It might also need that the unit is removed to be cleaned.
Nov 30, 2011 | Plumbing
High pitch noise when water is turned on.
that's a faucet problem, nothing to do with the tank
either replace the faucet washer (The one that's noisy)
or get a diffeent style faucet
Aug 31, 2009 | Water Heaters
Faucet Repair
A noisy washer-type faucet is usually caused by a loose seat washer. To stop the noise, first turn off the water and take the faucet apart as described previously. If the washer is loose, tighten it or replace it. After threading the stem back into the faucet body, try moving it up and down. If it moves, the stem is worn and the entire faucet must be replaced. Some faucets are noisy due to poor design and construction. The only way to solve this problem is to replace the faucet with a quality one.
Aug 27, 2008 | Danze D316440DNT Fairmont Two Handle Wall...
306 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
