Tip & How-To about Heating & Cooling
Unlock Lux 1500 Thermostat
Your Lux 1500 thermostat is showing the “lock” code and you cannot change your program. How do you get the thing to unlock so that you can make changes. The answer is actually very simple.
Hit the “next” button three times, then hit “hold” this will unlock your Lux 1500 thermostat.
http://www.fixya.com/support/r3898732-lux_thermostat_500
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
Heating & Cooling Logo
Hi I want to unlock zte blade Q Lux to Fiji Vodafone network. Please provide me with unlocking code? It requires 16 digit to unlock
I suggest you can approach Classicunlocking.com and specify the country,locked network of ZTE Blade Q Lux 3G .Based on the availability you can get the permanent unlock service along with free instructions.
Apr 26, 2017 | ZTE Cell Phones
locked out of thermostate
From the manual:
PROGRAMMABLE KEYPAD LOCK
To prevent tampering with any of your settings or
temperatures, the front panel buttons and the rotary dial can
be locked out, requiring a four digit code to unlock them.
You may use either the default lock code of "0000", or your
own personal number combination (see "Changing The Lock
Code")
LOCKING THE THERMOSTAT: Ensure the rotary dial is in the
RUN position. Press the NEXT button for at least 2 seconds.
The words "ENTER CODE" will appear on the screen, along
with "0000". Press the NEXT button again for at least 2
seconds. A padlock should appear on the screen to confirm
that the thermostat is now locked.
UNLOCKING THE THERMOSTAT: Ensure the rotary dial is in
the RUN position. A single press of any button should cause
the words "ENTER CODE" to appear on the screen, along
with "0000". If the default code was used to lock the
thermostat, press the NEXT button for at least 2 seconds.
The padlock should disappear from the screen, and the
thermostat should now be unlocked.
If you try to unlock the thermostat by entering a code that is
not correct, a padlock and the digits "88:88" will flash on the
screen and you will have to try again. If a lock code
different from the default was used, this will need to be
entered by using the UP/DOWN buttons, and the NEXT
button to advance to the next digit. Once the correct code is
entered, press the NEXT button for at least 2 seconds and
the thermostat should now be unlocked.
CHANGING THE LOCK CODE: To create your own specific
lock code, first ensure that the rotary dial is in the RUN
position. Press the NEXT button for at least 2 seconds. The
words "ENTER CODE" will appear on the screen, along with
"0000". Now press the HOLD button again for at least 2
seconds. The words "SET CODE" will appear on the screen,
along with "0000".
IF YOU FORGOT YOUR LOCK CODE: You can still unlock the
thermostat by performing the following steps: On the back
of thermostat locate JP1, which is a row of 3 metal pins at
the right edge of the circuit board above the battery tray.
There should be a plastic jumper cap on 2 of the 3 pins
(right or left).
Move the jumper cap so that it is on the opposite 2 pins.
For this change to be recognized, move the Temperature
Mode switch to any other position than its current one.
These steps listed should have changed the lock code back
to the default of "0000". Follow the instructions already
listed in "UNLOCKING THE THERMOSTAT".
Sep 02, 2012 | Lux Tx9100e 7 Day Universal Programmable...
lost manual for lux 1500 thermostat
Visit this link LUX INSTALLATION AND OPERATING INSTRUCTIONS SMART TEMP ELECTRONIC THERMOSTAT TX1500
Also in this other: Lux 1500 Thermostat Instructions (PDF)
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | Cameras
My lux TX1500a home ac thermostat unit is ''locked'' help !!
you press Next, Next, Next, Hold. This locks and/or unlocks the thermostat. I had the same problem but found the manual online.
May 18, 2010 | Heating & Cooling
5,765 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
