Tip & How-To about Sport & Outdoor - Others
How to build a backyard igloo!
Backyard igloos are easy and fun for kids. You don't need a large amount of snow, either. A few inches can be shoveled into a pile that's large enough for a kid to crawl into, but you need to be careful to make sure that you make it strong enough that it won't collapse easily.
Start out by piling the snow a couple feet high. Three feet is about as small as you can go, but that works well for most kids. It can be as big as you want, though.
After you pile it up, use a watering can to sprinkle the outside with water. It should be cold water, since hot water will melt the snow more than necessary. Make sure you cover the entire outside of the snow pile. The water is the key to making it strong.
Wait overnight for the water to freeze, and then use a shovel to scoop out the snow on the inside. Make a hole in one side with the shovel, and then carefully shave off the snow on the inside until you are close to the edge.
That's it! If the kids want, they can scrape out the snow on the inside with toy shovels, too. Overall time to do a small one this way is just an hour or so, not counting the overnight freeze.
Sport & Outdoor - Others Logo
Mototech mini quad. Where do I charge it
Looks like you need a battery charger. It has two 12 volt batteries. Didn't it come with a charger? And your parental control is via a key.
The MotoTec 24v Mini Quad v2 is the ultimate kids atv! Great for driveway and backyard fun, cruise over bumps and speed through dirt trails with ease. Comes standard with front & rear suspension, front & rear brakes and large 13 inch knobby pneumatic tires. This mini quad provides longer ride times than the competition with TWO large 12v 12amp hour batteries. New features include: headlight, key start, battery meter, forward & reverse, 2 speeds selectable by key and twist throttle with safety foot switch. SAFETY FIRST - ALWAYS WEAR YOUR HELMET AND ALL SAFETY EQUIPMENT AND OBSERVE SAFE RIDING RULES!!! Motor: 24 Volt 350 Watt
Battery: TWO 12v 12ah (24v Total)
Top Speed: 5 & 10 MPH (parental speed control by key) Recommended Age: 6+ years old (A parent's decision to allow his or her child to ride this product should be based on the child's maturity, skill and ability to follow rules.)
Max Rider Weight: 150 lbs
Frame: Steel
Tires: 4.10-6 Knobby Pneumatic (13 inch)
Brakes: 2 disc front, 1 disc rear (with parking brake)
Suspension: 2 independent front shocks, 1 rear shock
Throttle: Variable twist-grip (with safety foot switch)
Seat: Padded (single rider)
Handlebars: Adjustable Forward/Back
Battery Meter: Yes
Key: Yes
Headlights: Yes
Charging Time: 4-6 hours
Charger Included: Yes
Assembly Required: Yes
ATV Size: 42x23x25 inches
Handle bar height from ground: 25 inches
Seat height from ground: 19 inches
ATV Weight: 101 lbs
Box Size: 43x25x22 inches
Box Weight: 114 lbs
Product decoration and specifications subject to change without notice.
Warranty: 30 days parts replacement
MotoTec 24v Mini Quad v2 Blue
Dec 09, 2015 | MotoTec Kids ATV-24v Mini Quad
how do i get past the whirley street kids
you dont have to get PAST them all you have to do is get the snow shovel you DONT have to get past them....oh and Manny isn't past them
Nov 20, 2012 | poptropica.com
Where can I buy decent affordable outdoor chairs?
Home Depot and Wal-Mart have a great range of affordable butnice outdoor furniture.
May 29, 2012 | Garden
ds lite lego indiana jones game
IN the first level it is not indy who has the shovel the other guy has it on his back so you have to switch to him (switch characters by using X ) then he has to be standing in the right spot and shovel will appear ( you have to move a round and watch close for shovel to appear it is kind of finickey ) as for building i don't think you can have a weapon in your hands once you stand close enough the pile of lego will rattle press and hold A and you should build . hope this helps ya . I love this game once you get the hang of it it's super fun .
LKD
Jun 09, 2008 | Nintendo DS Lite Console
423 people viewed this tip
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
