Tip & How-To about Garmin nuvi 205 GPS Receiver
How to Perform a Hard Reset of your Garmin Nuvi 205 and 205W
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data)has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will beread from 'temp.gpx' into the non-user accessible memory area on theNuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
_______________________________________
Download Garmin Nuvi 205 Manuals here.
Garmin Nuvi 205 Favorites Backup here.
Garmin Nuvi 205 WebUpdater here.
Garmin nuvi 205 GPS Receiver Logo
hi my garmin nuvi 205w has gone into some kind of reset loop. when i power on it shows the garmin logo, then loading maps, then does 2 beeps and shows the garmin logo again and repeats this sequence. any pointers on how to turn on the device to functional mode again? thanks
Try the Hard Reset procedure outlined in this tip.
Ifpossible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
I hope that helps.
Jan 07, 2010 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi will not load maps - why
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Jan 07, 2010 | Garmin nuvi 205W GPS Receiver
Garmin Nuvi 1255 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260 Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390 Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490 Does your Garmin Nuvi 1255 Freeze at Loading Maps? Does it lock up or stop working? This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater. A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. Backup and Restoration Procedure for Favorites: The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.Perform the Hard Reset: *Note that this will clear all user selected settings on the unit Power the unit off. Remove the battery and wait several minutes. Install the battery. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears. Press "yes" and the unit will reboot. This resets all your location settings and user preferences. If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data. You have now performed a hard reset of your Garmin Nuvi 1255 GPS unit. I hope that helps. __________________________________________ Garmin Nuvi 1255 Manual Download Garmin Nuvi 1255 QuickStart Download Garmin Nuvi 1255 Webupdate Garmin Nuvi 1255 Favorites Backup Garmin Nuvi 1255 Hard Reset
Jun 18, 2010 | GPS
Garmin Nuvi 1490 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260 Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390 Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490 Does your Garmin Nuvi 1490 Freeze at Loading Maps? Does it lock up or stop working? This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater. A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. Backup and Restoration Procedure for Favorites: The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.Perform the Hard Reset: *Note that this will clear all user selected settings on the unit Power the unit off. Remove the battery and wait several minutes. Install the battery. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears. Press "yes" and the unit will reboot. This resets all your location settings and user preferences. If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data. You have now performed a hard reset of your Garmin Nuvi 1490 series GPS unit. I hope that helps. __________________________________________ Garmin Nuvi 1490 Manual Download Garmin Nuvi 1490 QuickStart Download Garmin Nuvi 1490 Webupdate Garmin Nuvi 1490 Favorites Backup Garmin Nuvi 1490 Hard Reset
May 27, 2010 | Garmin nuvi 1490T GPS Receiver
16,134 people viewed this tip
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
