Tip & How-To about Computers & Internet
How to clean PC RAM with Eraser
As we all know that Memory is most important part of your computer and sometimes it gets rusted and does not work and as a result you listen several beeps from your computer regarding RAM Error.
One of the best and easiest way to keep your PC RAM clean and prevent it from getting rusted is to do the following:
  1. Take the RAM out of the slot of main board.
  2. Take any kind of eraser that you use to remove your pencil mistakes (rubber). Do not use any hard rubber please!
  3. Once you have both things, simply rub the eraser on the Golden surface of the RAM which usually goes into the slot and keep on rubbing the surface until the rust or other unwanted material gets away and that Golden part starts to shine.
  4. After you have done this, take Cotton swab or soft cloth to clean the particles of eraser.
  5. Apply the same procedure to other side of the RAM.
  6. That is it.
You can protect other things that use to be in the slots like PCI Cards, Modems, Sound Card, AGP etc... Enjoy Computing!
Regards,
Khawar Khalid
Computers & Internet Logo
why i get error 0xc00d11df while trying to listen radio from music app on win 8.1
it happens when your operating system becomes misconfigured, important system files get Corrupted . This is a common problem with computers that don't get maintained regularly. Eventually the system becomes overloaded with problems and begins to display SystemErrors. Due to the Operating System now not functioning correctly a weakness in the System Security Policy and internal controls will be exploited and result in a security breach or Violation in the system's security policy.
Jul 08, 2014 | Microsoft Computers & Internet
Canon PowerShot SX20 IS Digital Camera freezes when importing pictures
Try downloading the current software for you model from the Canon site. You could try inserting the memory card into the card reader on your computer and if you get the same result then it would appear to be a software problem that you use to download. Sometime conflicts appear.
Nov 01, 2017 | Canon PowerShot SX20 IS Digital Camera
89 B2600I: engine starts and runs if you spray starting fluid in air intake- you quit then it quits. Injectors have 12 volts. computer has constant & ignition 12 volts plus several good ground connections. Tried another computer & got same results. Has new, complete distributor and new fuel pressure regulator. Didn't test fuel pressure but it has lots of pressure and fuel at the injectors.
So we would have to assume from what you're saying that the injectors are not being pulled to ground by the computer. Have you tried listening to them with a mechanics stethoscope? The computers are a common problem but if another one gives the same result then I'd have to say that the wiring harness between the computer and the injector is suspect. You will have to check the continuity between the injector plug and the connector that goes into the computer. You will need a wiring diagram but I think the wire colors at the injector should be the same as they enter the computer. I would strongly suggest that you confirm fuel pressure though. I know what you mean by fuel at the injectors, but pressure is important.
Jun 05, 2011 | 1989 Mazda B-Series
How do I get the check engine light to go out after I've replaced the o2 sensor?
You can try disconnecting the battery for several minutes. Sometimes this works sometimes it doesn't. If the light goes out it doesn't necessarily mean that the code has cleared from the computers memory.
The best way is to use a scan tool or a code reader. That way you know the code has been cleared from the computers memory.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 17, 2010 | 2002 Dodge Caravan
i have spent hours trying to transfer music from my pc to w995. I transfer my music to the sync list, try to sync, and get a message in the sync list that the tracks "did not fit on device". I have 5 gb of available memory. Some tracks get synced and some dont, but sometimes tracks that have been synced get lost after i have synced them. I use the w995 as my mp3 player and have several hundred songs on it, i pretty much know what i am doing, but recently it will not sync music as it should. Has anyone experienced this or more importantly does anyone know of a solution?
I can tel you some other way to transfer music files into your phone instead of doin sync. Connect your phone to PC via USB. Now your phone will ask to select on eoption. Select Mass Storage. Now you click my computer in your PC & select memory stick drive there. this is a direct access into your phone memory stick. Select the music file you want & copy paste it into music folder in your memory stick.
Feb 26, 2010 | Sony Ericsson Walkman® W995 Cell Phone
2,364 people viewed this tip
David Payne
David Payne
