Tip & How-To about iRiver E10 Digital Media Player
Apple Compatability
Iriver:
Hello! This is iriver supporter. Please enter your question, then simply click 'Go' button or press Enter key.
Maxicube:
[H10 H100 H300] apple software
iriver:
Are you asking me that "(Harddisk Player)You want Macintosh compatibility information"?
Maxicube:
Yes.
iriver:
H10 & E10 Players
H10 Players are only compatible with Windows XP. They cannot be used on Windows 98SE / Me / 2000 or Macintosh computers.
H100 Series, H300 Series and iGP players
The H100 Series, H300 Series and iGP players are compatible with Mac OS versions 9.2.2 and 10.2 or higher. When attached, the player will display as an icon on the desktop. Open the icon to add files to the player. Note, the DB functions described in the manual are not available for Mac OS at this time, as the index cannot be created with Mac OS. This means that Album, Artist, Genre, and Title searching will not be available.
For The Iriver Bot Goto http://www.iriveramerica.com/support/contact.aspx
iRiver E10 Digital Media Player Logo
corrupt firmware
For recovery tools for the H10 go to next site:
http://www.iriver.com/flash/index.asp?code=0302
Next enter the word recovery in the second column next to GO.
Now the recovery tool should show up in the right side of the page.
Click the download [MTP]H10 5G/5G Pure/6G Firmware Upgrader/Recovery Tool(US & EU only) for more information.
See the recovery tool iRiverFirmwareUpdater.zip.
Follow up the instructions for the recovery.
Need more help ? Jus post a comment.
Dec 11, 2009 | iRiver H10 MP3 Player
changing hard drive
before you do this take the software off iriver even the hidden (place it onto pc)
make sure the hard drive you wish to place into your h10 is perfect match (it could be more gigs) you just want the size and speed....here you go http://www.youtube.com/watch?v=mKQFEweay1Y
i still have iriver h100 (with a toshiba 40gigs) before the h140 came out
have fun
May 02, 2009 | iRiver H10 MP3 Player
System files missing
I fixed this problem for my mate, here's what I did:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Here is for the Iriver H10 software:
http://iriverinc.com/support/hd/h10_5-6gb.aspx
Apr 13, 2009 | iRiver H10 MP3 Player
restore the system files, connect H10 to recovery tool
The procedure depends on what version you have.
Below there is the procedure for 20 GB , on other models procedure is the same, but you must find the right download for your model.
For 20 GB :
TO RESTORE "SYSTEM FILES MISSING" LOCKED PLAYER
--- This applies ONLY to the 20 gig version of the H10! ---
--- This procedure formats your H10 so all data will be erased on the player! ---
1. Power off H10 - 20gig unit.
2. Insert staple or other small object into reset hole to press reset button.
3. Connect player to USB cable.
3. Hold down Select key (labeled "O" - right button on front of player) while also holding down power key until player boots.
4. Unit must display "Emergency Connection."
5. Unit will now appear as a drive under My Computer. Right click on drive, select Format. No need to change anything, just proceed.
6. Download H10_20GB_System.exe. It is a self-extracting archive. Double click on it and unzip to c:\iriver.
http://www.iriveramerica.com/downloa...0GB_System.exe
7. Locate iriver directory, double click. You will see H10. Double click once again; you will see System.
8. Right click on system, select "Send to" and choose the directory of the player.
from System Files Missing
If you have the 5 or 6 GB see iriver - H10 5/6 GB Series Support
Feb 24, 2009 | iRiver H10 MP3 Player
iriver H10 20Gb Jammed
Hi StevieB Try following.1/Prepare a handy tool (straightened paper clip) to insert into "reset" hole atop of H10 2/gently insert tool into reset hole and feel a click 3/ turn on H10 if this works great 4/if H10 continues to jam lock up then it may require reloading firmware sounds complicated but easy steps available chk iRiver support website
Mar 28, 2007 | iRiver H10 MP3 Player
1,799 people viewed this tip
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
