Tip & How-To about Computers & Internet
How To Increase The Speed Of Computer
In this post i will show you how to increase the speed of your computer
It is very easy to increase the speed of your computer all you need to do is
First of all Go to Start Menu Then Click on Run
After that first type msconfig and press enter
Then an anothor window will open
click on the startup Tab
The click on Disable all (this disables all the startup programmes and hence the systems speed will increase
Then next step is “again go to run” then type “%temp%” (without qoutes)—
Then a folder will be opened After it is opened Just clear all the files present in that folder
;And after doing this just restart your computer You can see the difference then..
Computers & Internet Logo
Does Mac defragmentation help to speed up performance?
Defraging the hard drive will speed up file access because the files will be contiguous and the hard drive read/write head/s does not have to skip all over the disk to retrieve the files.
As for speed increase there will be some imrovement.
Installing more RAM will also speed up your computer.
Feb 06, 2013 | Computers & Internet
SPEED UP INTERNET
Windows OS user can speed up internet up to 20%. Actually windows reserve this 20% speed for update and other purpose. You can get back this speed. To know more, visit : Increase your internet speed up to 20%
You may speed up internet using public DNS server. To more detail, visit : Speed up internet by DNS setup
To know more about computer, internet and mobile phone tips, visit : 001 Easy Tricks
Feb 01, 2013 | NetGear Computers & Internet
i cant overclock my system but i go to bios now whati had to do
The BIOS. Overclocking is best done in the computer's BIOS (Basic Input/Output System or Binary Integrated Operating System). There are also some motherboards that let you do a basic increase in power by setting a jumper, but this is dangerous and you have no real stability control.
There are some software programs available which allow you to overclock inside the operating system, but the best results are achieved by changing BIOS settings. Usually you can get into your BIOS by pressing DEL (some systems may use F2, F10, or Ctrl-Enter) as soon as your computer begins the POST
(Power On Self Test - when it shows the RAM size, processor speed, etc.).
Here, you can change your FSB (front side bus), memory timings, and your CPU multiplier (also referred to as CPU Clock Ratio).
Clearing your CMOS. Sometimes, an overclock can become unstable. If this happens, or your computer will not boot, you will need to reset the BIOS back to default and start over again.
This is done by clearing the CMOS (a small piece of memory on the motherboard which stores your BIOS configuration, and is powered by a small battery). Some newer motherboards will bypass user settings in the CMOS if the computer fails POST (often caused by a faulty overclock). However, most motherboards require a manual clear.
This can be done in two ways, depending on your motherboard. The first way is by changing the position of the clear CMOS jumper on your motherboard, waiting a few minutes, then repositioning the jumper to its original place.
The CMOS Jumper
The second way, if your motherboard doesn't have this jumper, consists of unplugging your computer, removing the little CMOS battery, then pressing the power button (your capacitors will discharge), and waiting a couple of minutes.
Then you have to refit the battery and plug in your computer. Once your CMOS is cleared, all BIOS settings are reset back to default and you'll have to start the overclocking process all over again. Just so you know, this step is only necessary if your overclock becomes unstable.
Locked or Unlocked. The first thing to know when you start the process of overclocking, is whether your processor is multiplier locked or unlocked.
To check whether your CPU is locked, lower your multiplier via the BIOS one step, for example from 11 to 10.5. Save and exit your BIOS and your computer will restart.
If your computer posts again and shows the new CPU speed, it means your CPU is unlocked. However, if your computer failed to post (screen remains black) or no CPU speed change is present, this means your multiplier is locked
Multiplier Unlocked Processors. Usually, your max overclock is limited by your memory, or RAM. A good starting place is to find the top memory bus speed in which your memory can handle while keeping it in sync with the FSB. To check this, lower your CPU multiplier some steps (from 11 to 9, for example) and increase your FSB a few notches (e.g.: 200 MHz to 205 MHz).
After this, save and exit your BIOS. There are a few ways to test for stability.
If you make it into Windows, that is a good start. You can try running a few CPU / RAM intensive programs to stress these components. Some good examples are SiSoft Sandra, Prime95, Orthos, 3DMark 2006 and Folding@Home.
You may also choose to run a program outside of Windows, such as Memtest. Load a copy of Memtest onto a bootable floppy, then insert the disk after you have exited the BIOS.
Continue to increase your FSB until Memtest starts reporting errors. When this happens, you can try to increase the voltage supplied to your memory.
Do note that increasing voltages may shorten the life span of your memory. Also, another option is to loosen the timings on the memory (more on this a bit later). The previous FSB setting before the error will be your max FSB. Your max FSB will fully depend on what memory you have installed. Quality, name-brand memory will work best for overclocking.
Now that you know your max FSB, you'll figure out your max multiplier. Keeping your FSB @ stock, you raise your multiplier one step at a time. Each time you restart, check for system stability. As mentioned above, one good way to do this is by running Prime95.
If it doesn't post (reread the section about clearing the CMOS), or Prime 95 fails, you can try to raise the core voltage a bit. Increasing it may or may not increase stability. On the other hand, the temperature will also be increased. If you are going to increase the core voltage, you should keep an eye on temperatures, at least for a few minutes.
Also note that increasing voltages may shorten the life span of your CPU, not to mention void your warranty. When your computer is no longer stable at a given multiplier setting, lower your multiplier one step and take that as your max multiplier.
Now that you have your max FSB speed and your max multiplier, you can play around and determine the best settings for your system. Do note that having a higher FSB overclock as opposed to a higher multiplier will have a greater impact on overall system performance.
http://www.pcadvisor.co.uk/news/index.cfm?newsid=107977
hope this helps
May 30, 2012 | Computers & Internet
volvo air conditioning doesnt work s60
you need a blower motor resistor
Oct 30, 2009 | 2001 Volvo S60
about speed up my computer
hi
lets take you are using windows xp pls follow these steps.
1.clean temp files every 3 days.
2.delete the files from "pefetch" type in run
3.increase your ram capacity.
4.set your appearence to "better perfomance"
5.keep minimum virtual memory as 1024 mb.
6.use registry cleaner (available in internet) after uninstalling the softwares.
this will help you for better performance
Mar 20, 2008 | Microsoft Office Professional 2007 Full...
170 people viewed this tip
David Payne
David Payne
