Tip & How-To about Audio Players & Recorders
How to get the most out of your iPod battery
When you first get the iPod make sure to fully charge it. Then only charge the iPod when it is so dead that it will not stay on long enough to play anything. Then allow the battery to charge until a screen appears saying fully charged. This may seem redundant but it ensures the batteries capacity will be maximized for as long as possible. There are only about 1800 charge cycles in an iPods battery life. This may seem like a lot of charging ability but when you wish to keep the iPod for more than a year and a half it becomes more realistic that it is not.
Above all else, never ever remove the iPod from the computer without ejecting it first.
If you are for some reason unable to properly eject the iPod, first shut down your computer before removing the iPod.
My Altec Lansing Inmotion used to charge my Ipod Touch, but since yesterdag (after not using it for 3 weeks) it won't charge my Ipod anymore. The Altec charges itself, but somehow the Ipod doesn't. It is not really a connection problem because it still plays the music through the speakers. I hope to hear from you soon.
That is a tough one. Is your iPod fully seated -- will it play music in the im600? Have you tried a different iPod in the im600 to see if it charges? Does your iPod recharge normally in other players, in a wall charger and your computer? If not, your iPod could possibly need a new battery.
Also: since it was unplugged for 3 weeks, you may just need to run the im600 through a full cycle or two (let the FM radio play until the battery is dead, with no iPod in it), then recharge the im600 for 5 or 6 hours, and THEN mount your iPod into it and see if it charges it. Be sure to unplug/plug-in the adapter into the im600 to ensure it is getting full power from the wall outlet. One last thing: the im600 will only charge the iPod when it is plugged into AC power; it won't charge the iPod while it's running on its own battery power. Good luck!
Jan 16, 2011 | Altec Lansing Inmotion-IM600...
1998 chevy lumina want start changed starter and battery still want start turn key car dead want turn over can start with jumper swicth but want stay running
Have your alternator tested.Your car will not stay running if the alternator is not producing enough power to keep the battery charged.Also have your battery tested and fully charged.Make sure your cables are in good shape.
Sep 26, 2010 | 1998 Chevrolet Lumina
my ipod wont stay charged
This may not be the answer you are looking for but your I pod might not be fully charged, meaning that you are not plugging it in the computer/docking system long enough.( it takes much longer than 15 minutes to charge the battery. So you might want to plug it in/dock it over night) Or you may be playing a game that uses a lot of MB/GB so it kills the battery. And make sure that you press the play/pause button down for at least five seconds before switching the little switch at the top of your I pod. If you don't press the play/pause button for five seconds and just switch the switch at the top a little lock will appear on the left corner meaning you need to hold the play/pause button down for five seconds then the i pod screen goes black at that time flick the switch at the top off. -hope it helps owner of i pod nano and I pod touch.
Dec 30, 2009 | Apple Mini IPod
Battery Symbol and "charged" stay on iPod screen
You could try restoring the software back to factory defaults and see if something is missing. Make sure it is fully charged before doing it.
Aug 08, 2008 | Apple iPod nano
8 GB Ipod Nano went dead and now won't charge
does it work on the charger? if not, then contact apple or your dealer for more assistance or repairs.
If it works on the charger, plays music and so on, your battery is probably dead and you need a new one.
Mar 24, 2008 | Apple iPod nano
204 people viewed this tip
 Grubhead
Grubhead
