Tip & How-To about Cell Phones
Nokia phone codes
Here are all the codes nokia phone accept and what each code does;
x#06# is your imei number
x#7780# this resets your phone to factory settings
x#67705646# this removes the operators logo
x#0000# this shows you the software version on the phone
x#2820# bluetooth device addresse
x#746025625# sim clock allowed status
x#62209526# this displays the mac addresse of the wlan adapter
#pw+1234567890+1# shows if sim has restrictions
x#92702689# takes you to a secret menu where you may be able to do the following;
1 displays serial number
2 displays month and year it was made
3 displays the date when phone purchased
4 shows date of last repair
5 shows life timer of the phone
x#3370# Enhanced full rate codec or efr activation increases signal strength but drains batt alot quicker
x#3370# will also deactivate the efr
x#4720# is half rate codec activation
x#4720# will deactivate half rate codec
if you have forgot the wallet code for s60 phone then use this code to reset x#7370925538# your data in the wallet will be erased then the phone will ask for lock code witch is then 12345
x#3925538# this erases whats in the wallet
x#7328748263373738# this resets the security code to 12345
you use these codes at your own risk also these codes willl only work with certain models and this also depends on the software version on the phone.
In no way am i telling you to use these codes they are just their as a referance and can be used at your own risk
Cell Phones Logo
sir my mobile not accepting my security code which i forgot how can i unlock my phone now i am from pakistanmobile imei no is 359741004043747
If you have forgotten the security code for your Nokia 6030, you can do a master reset to your mobile. this could restore your phone with default factory settings. So your security code also changes to default code 12345. You can get the master reset code for your Nokia 6030 from www.unlocking4u.com/nokia-dct-master-code-service/rs6wp10/ at affordable cost. all the best mate.
Aug 01, 2012 | Nokia 6030 Cellular Phone
phone reset code
Hi, the N70 is a Symbian handset and there are two reset codes you can try
the firs will reset setting and keep user data : *#7780#
the second will reset the handset to factory setting *#7370#
the security code is usually 12345 or 0000
Jul 30, 2012 | Nokia N70 Cellular Phone
Please help me I have forgoten my cell lock code my IMEI:354199026531527 its a Nokia 6210 navigator and to reply please email nmgumbi@dla.gov.za
  • *#7370#Format phone (Soft Reset).
  • *#7780#NOKIA Factory Reset (Hard Reset).
  • To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
  • on/off + * + 3
    • Before making a Hard reset better backup all your important information
Jun 23, 2010 | Nokia N73 Cellular Phone
i tried to restore factory setting in my mobile but the code 12345 is not accepting, is there any master code?
To restore any nokia phone to it's original state, it will ask for a security code, and the default security code for all nokia phones is 12345 except you or someone else have changed it. If the phone is not accepting 12345 as the code, it means it has been change. If you cannot recollect the new code. then you have to unlock the other way through the use of your imei number which can be found behind the battery in the phone. Take your phone to a mobile phone technician to unlock it with the use of the imei number.
Jan 19, 2010 | Nokia E71 Smartphone
192 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
