Tip & How-To about Computers & Internet
Picasa 3 is the latest release of thesoftware from Google, and comes as a much amped up successor to Picasa2.7. Some features have been added, and some functions have beenchanged. Overall, it is an improvement, with a markedly better upload(a lot less failures), some nifty new features, but a slightly buggingand confusing interface. It is a pain to add pictures, the automaticscanning goes haywire on your hard drive (we recommend not settingPicasa 3 loose on your hard drive to scan the folders automatically),and adding folders manually mysteriously fails from time to time.However, the hosting facility is one of the best free ones around, sothis is taking you through some of the interesting stuff you can dowith the software. [View All Portraits: This is a really interesting feature inPicasa. You can view all the photos across all the albums with faces.To the left of the search bar, on the top, click on the face icon.Click on the icon again to get out of this mode, or click on ?back toview all?. This is a filter, the other filter for photographs availableis all the pictures that are starred. Upload A Slideshow To YouTube: Select the ?Movie? button in the bottombar of Picasa. The first slide will be a text slide to introduce theslideshow. Rearrange the photos, add captions, select a music, selectthe transitions, and preview the slideshow a few times. Once you aredone, click on save movie, and then use the YouTube upload button inthe interface to put the movie on YouTube. Needless to say, you need tohave a Google account and an Internet connection for this feature towork. Sync Picasa3 Software And Web Albums: On the top right corner, above the albumor folder is the sync button. Using this feature automatically savesall changes you have made to your copy of the album to the version ofthe album on Picasa. This works for changes to the file, the tags, andphotos added or deleted to the album. This does not work forre-ordering the photos around in the album and changes made to the filenames. Touch Up Photos: This is used to remove spots from thesurface of the lense, artefacts caused due to dust particles or waterdroplets, and scratches and dust from old photographs. Double-click on an image once it isadded to an album. Under the ?Basic fixes? tag, select ?Retouch?. Usethe ?Brush size? slider to select a brush size. Ideally, you shouldselect a brush size a little larger than the size of the artefact youare trying to remove. Click once on the blot, and click to a similarplace elsewhere in the picture. The smaller the brush size, the lessnoticeable the patch up will be. Hovering over different parts of thepicture, you should see the blot getting covered up. You can undo a badpatch in this window itself. Once you are done fixing everything, clickon apply. If you want to undo your changes, you cannot automatically redo them. Screencapture Album: As long as Picasa is running, taking ascreenshot of the screen using the [Print Screen] button will save theimage and add it to Picasa. Improve All Your PhotosThis feature works to different degreesof effectiveness for different photos, but is one of those buttons thatlooks like magic. If you trust Google more than your photographyskills, select an album go to Picture > Batch Edit > I?m feelinglucky. There is no explanation for exactly what this does to yourphotos, but some photos were improved, some were horribly damaged. Copyall your files to another folder before you try this though, beforesomething goes horribly wrong. CollageThe collage view in Picasa is ainteresting little feature to give previews for your Web albums. On topof the folder or album, next to the play slideshow button, is the MakeCollage button. Click on this button, and you will be taken to thecollage window. The default collage option is the picture pile, withthree border settings, no border, white border, and instant cameraborder. If your pictures are captioned, the captions will show up nextto the photos in the collage. There are five other collage optionsavailable, mosaic, frame mosaic, grid, contact sheet and multipleexposure. The mosaic arranges pictures in blocks of random sizes. Theframe mosaic displays one image in the centre, and frames it with theother photos. The grid and contact sheet have cells of equal sizedimages, and the multiple exposure mosaic is a strange option tosuperimpose all the images in an album on top of one another. Do notuse this option even by mistake in an album or folder with a lot ofphotos unless you want to crash your computer. Search For Photos By Colour: This is an experimental feature inPicasa 3, that lets you search for all the photos with a color scheme.Google searches for Red, Orange, Yellow, Green, Blue, Purple and BWphotos. We wish they would have included a colour picker for thisfeature. Go to Tools > Experimental, and search for and click acolour. The orange search returns everything from red to yellow. Thegreen and blue searches are most accurate. The black and white searchesreturns all pale and grey colors, not photos that are strictly blackand white. Customise The Bottom ToolbarPicasa 3 allows you to remove the rarelyused features from the bottom toolbar. Go to Tools > Configurebuttons, then remove, add or re-order the buttons as per yourrequirements and save the settings. Get Rid Of Duplicate FilesTo get rid of duplicate files, go toTools > Experimental > Show duplicate files. Then select one copyof the files and press the delete button. Copy protect your photosTo automatically add a watermark to allthe photos you upload to Picasa, go to Tools > Options and thenselect the ?Web albums? tab. Check the ?Add a watermark for all photouploads? checkbox and edit the text in the field. The photos uploadedto Picasa will have the watermark, but the photos on your disk will beuntouched. Adding A Watermark To All Photos: To automatically add a watermark to allthe photos you upload to Picasa, go to Tools > Options and thenselect the ?Web albums? tab. Check the ?Add a watermark for all photouploads? checkbox and edit the text in the field. The photos uploadedto Picasa will have the watermark, but the photos on your disk will beuntouched.
Computers & Internet Logo
What are the new core features in Wordpress 4.8 Beta release?
List of core value added functionalities with Latest WordPress Version 4.8 :
There are three Core functionalities, which WordPress added in this latest beta testing version were focused on WordPress Widgets.
Improved visual Editor Experience with TinyMCEIntroduction of News and Events Widgets for WordPressNew widget for Image, Video, TextImproved Visual Editor Experience with TinyMCE The new version of WordPress comes with TinyMCE as its core feature which improves your visual Editor experience. It lets you navigate more intuitively in and out of inline elements like links. It's easy to explain it with the Gif below.
News and Events Widgets for WordPress With a goal to guide & update WordPress developers community a new dashboard news widget is integrated as its core functionality that let you see nearby and upcoming events including meetups and WordCamps. One can also enter city or region and a list of nearby events will be infront of him.
New widget for Image, Audio, Video, Text The most important update in this new release is introduction of Image, Video, Audio and Text widgets.
Text Widget In previous version, WordPress just use Plain Text Widget where you can add plaintext or html code. The problem with this widget is that those who are not well versed with coding found it difficult to integrate html code in it.
The upgraded widget in WordPress 4.8 comes with a simple visual and text editor. Similar to the one you see on the post edit screen.
Image Widget With this widgets now you can easily insert images anywhere in widget area like sidebar or in footer space.
know which new feature you like the most in this WordPress 4.8. in comment section.
Video Widget Same as Image Widget you can now easily introduce Video anywhere in widget area.
If you want to test this changes by your own then had to install a plugin called beta tester plugin. This plugin allows you to update your WordPress version to a latest beta test version.
Updates after WordPress 4.8 beta 1 released:May 17, Weston Ruter, WordPress core committer & contributor, AnnouncedWordPress 4.8 Customizer sidebar width is now variable.May 22, Weston Ruter, WordPress core committer & contributor, Announced ,WP 4.8 ends core embedding support for WMV and WMA file formats.More Coming Soon and will be updated in this blog as soon as we got news from WordPress...
If you encountered a bug, then you can report it to WordPress at Alpha/Beta/RC Forum.
We personally like this upgrades regarding new widgets.
Let us
source : http://www.vedwebservices.com/core-functionalities-with-latest-wordpress-4-8-beta-release/
May 24, 2017 | Core Computers & Internet
Downlad issue with Picasa from Google Chrome
Create a known folder for it to download too. And on the options to save - select that folder. Then retry.
Jul 05, 2013 | Google Picasa
I have attached the usb cord from the camera to the computer, but the pictures don't come up. Nothing happens. This is a new problem.
As a work-around, you should try using Picasa to download the pictures off of your camera.
Picasa is a free download from Google and has many cutting-edge features for picture management. I think that you'll like it.
  • Download Picasa from their web site (click here) to your Desktop
  • Once the Picasa file has completed downloading, Open the file and follow the directions displayed.
  • Once you have Picasa installed, connect your Olympus camera. Picasa will recognize that you have connected the camera and ask you how you want to proceed.
  • Have Picasa copy the images from your camera
  • You can then use Picasa to handle the photos from your camera.
Let me know if you have any questions.
Thanks for using FixYa and Happy New Year!
Jan 01, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
177 people viewed this tip
David Payne
David Payne
