Tip & How-To about Refrigerators
Refrigerator is not cooling enough or it does not cool at all!!
There are few Steps that you could Verify and narrow down the problem :-
1. Compressor - Make sure that the Compressor should be working. When you ON the refrigerator, you could hear a clicking sound from the Compressor.Compressor could be Hot but not enough to lay eggs on it.
Note - In case, you find that the Compressor is Clicking and Shut Down the machine every now and then, more often that's an indication of Faulty Compressors. With most Brands, they do come up with 5 Years Warranty.
2. Make sure all the Fans are Working. I have seen many times, that the Fans are not working and the people are Inspecting other Components in the Refrigerator.They should also be running at Optimum Speed.
3. Do you see any Ice in the rear of the Freezer? More often - Frost. ( Not Crystal Clear ). If yes, take a Blower / Dryer and melt it. You would see a complete Difference.
4. Make sure that the Condensor Motor is working. If you could hear Condensor Fan is running, it always indicate that the Motor is Fine too.
5. How many times we never clean up the Evaporator Coils? We are using it for Years and we never clean it. So, if this is the Case, time to Take a Vacuum and clean the Evaporator Coils.
6. It could be a Defrost Problem. There are many Components but How could you make sure?
The Best Way - Disconnect the Power Supply and Unplug the Cord. Take everything out of the Refrigerator. Keep the Doors Open for 24 hours. After 24 hours, plug in the Cord and then Turn ON the refrigerator.If you see that there is Some improvement, more likely you have faulty Defrost System.
7. On other Occasions, i have Found Overload Relay to be one of the reasons. I solved many Problems where the Customer Actually Test and Find that the Overload Relay is at Fault.
Note - There could be Freon Leak or Gas Leak which i am not considering right now. You need to contact a Licensed Professional t check these.
Hope the above information might have Helped you to Fix the Problem.
Thanks a lot for taking your Valuable Time and Reading this.
Thanks for using ' Fixya ' and have a nice day!!
Refrigerators Logo
how do I fix fan wont shut off
In front of the 04 code, what is the "F" code is needed for help you. There are 4 different possible answers for this issue.
FAILURE/ERROR DISPLAY CODES Before proceeding with any corrective action, perform the following steps to enter the Diagnostics mode: 1. To recall last failure code, if not displayed, press the Cancel key to place the range in an idle state. 2. Press the Cancel and Start keys in the following order: CANCEL, CANCEL, START. 3. Verify the error code displayed on the control by observing for longer than 1 minute. If the error returns, use the applicable procedure listed below for the actual error code that is displayed.
With this information, I can narrow down the cause and possible repair on you unit. Thanks
Apr 11, 2016 | KitchenAid Kitchen Ranges
Why won't my wireless keyboard work?
Hi there
If your wireless keyboard worked at one time, my guess is, it is compatible, but you may just need to adjust a few settings. Did you previously go through the steps of setting up the device, or did the keyboard begin to work, upon plugging it in? A few things you can check, before attempting to reinstall the keyboard are as follows:
1. Make sure your Bluetooth device is on and is discoverable
  1. Turn on the device and make it discoverable (varies by device, check information that came with device)
2. Make sure Bluetooth is active on Surface
  1. Open the Settings charm, then tap or click Change PC Settings
  2. Tap or click Wireless
  3. Make sure Bluetooth is set to On
3. Check to verify the keyboard is listed under available devices.
  1. Open the Settings charm, tap or click Change PC settings.
  2. Tap or click Devices to see a list of available devices.
If your keyboard does not show up in the list of available devices, I would recommend going through the steps of adding the device.
Hopefully that works for you, but should you have further problems adding a device, see Troubleshoot Bluetooth.
May 21, 2014 | Computers & Internet
I have an lg split system airconditioner. The unit starts up fine and runs for a few minutes. After a few minutes it trips the circuit breaker. Could you tell me what causes this? Thank you
Sounds like an electrical problem.. or the compressor is beginning to fail. Check the wiring connections on top of the compressor for burning etc ... If OK, the compressor may be shorted out.
Make sure the power has been switched OFF before any testing is done.. Usually an LG will show a fault code on the display on the internal unit but a dead short on the comp will happen to fast for this to occur. One way to isolate a compressor fault is to disconnect it.. If the unit runs ( fans etc) with the comp disconnected and does not trip the breaker , then you have narrowed down what the fault is.
Jul 14, 2011 | Heating & Cooling
my kenmore model # 580.5450.1801 runs, but does not produce water. It is a humid basement, and another unit is working.
Turn the unit on and verify the compressor is running. If it is let it run for 3-5 min then unplug and plug it back in. If the compressor comes back on immediately there is a leak and the system needs serviced. If the compressor is not running further investigation to narrow down the cause is necessary. If the dehum is out of warranty replacement is the better option when sealed system repairs are needed.
Eric
Jul 16, 2010 | Kenmore Dehumidifiers
I have a Whirlpool Refrigerator model no: 6GC5THGXK500. It is not cooling. When I turn power on, the fridge lights ON and I can hear the fan running inside the freezer compartment. TQ
Mar 07, 2010 | Refrigerators
2,317 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
