Tip & How-To about Computers & Internet
How to format a hard drive in windows XP
When you format a computer hard drive, you will lose everything that is on the drive. Therefore, it is very important to back up anything you might want later. Also you need to have the operating system that you are going to be installing after the format (so make sure you do) . Backup anything that you don't want to loose on a seperate cd, dvd, or external hard drive that you are not going to be formatting.
Now first of all, Right-Click on the "My Computer" icon either on your desktop or in the Start Menu and select "Manage", a new window titled "Computer Management" comes up. Select "Storage" from the left hand side by clicking it once, then select "Disk Management(local)" from the right side by double-clicking it.
Now in the lower part of the main frame of the window you should see a nice visual of all your hard drives. Each line is a different drive. Each box on a line is a partition on the drive. Partitions are separations of space on a drive. Unless you are doing something specific that requires multiple partitions, you only want one partition per drive.
First you must delete any existing partitions on the drive you are going to format. Do this by right-clicking on the partition's box and selecting "Delete Partition.. Click yes for the prompt "are you sure", and whatever other warnings you might get, as long as you have backed up everything you need.
The box for the drive to be formatted should now have a black bar at the top of it and should say "Unallocated" under its size. Right click on it and select "New Partition..." The New Partition Wizard comes up.
In the New Partition Wizard click next. On the next page make sure "Primary Partition" is selected and click next. Now make the size equal to the maximum (it should already be set to it), and click next again. On the next page the computer will automatically choose the first available drive letter for the new drive. However, if you like you can choose another drive letter from the drop-down menu, and then click next. Finally the New Partition Wizard asks if you would like to format the new partition and if so what format. Choose "NTFS" as it is faster and more secure. Leave the "Allocation unit size" as "Default." In the "Volume label" field enter whatever name you want the drive to have. After that, check the "Perform a quick format" box (If the drive has been used before you can leave this box unchecked). Leave the "Enable file and folder compression" box unchecked and click next. Then on the next page click finish. The wizard will now spend a little while formatting the drive. On old or large drives this may take a while. Do not close the "Computer Management" window until it finishes. You will know it is done when the word under the size of the drive changes from "Formatting" to "Healthy" and the name and drive letter you chose for the new drive show up. After it is finished you can now use your newly formatted drive.
Computers & Internet Logo
What can I do to rescue needed files from RAW Seagate hard drive?
Well in this case i suppose you need backup help and for that technical people can better guide you.
Nov 07, 2014 | Computers & Internet
I didn't close all the programs on my LG HXD7 1TB hexternal and took it out without ejecting it now it says I have to format it. What can I do to fix it without formatting it and loosing all my da
You'd better never do such improper operations again.
But, right now, in order to get back your data, you are supposed to act carefully as below:
1). Do not format this hard drive in case that anything important will lose at the same time.
2). Do not add any new file on this hard drive in case that anything new would rewrite your original data.
3). Do not randomly select a hard drive data recovery program. In your case, an efficient data recovery program always means a lot. Therefore, you can try to apply an unformatted drive data recovery freeware to get back your player data successfully:
http://www.freeware-fix.blogspot.com/2013/03/unformatted-hard-drive-recovery-freeware.html
4). Do not save the restored data on the same drive in case of data recovery failure.
5). Do not forget to format this drive after the data recovery process so that you can check whether this "not formatted error" problem could be resolved.
Note: Never try to save everything important on only one hard drive next time.
Dec 09, 2012 | Computers & Internet
I have a Verbatim 500Gb (model #47566) hard drive. After defrag and clean up, when plugging in, I get a message that the disk in drive K is not formatted and would I like to format it now? I know that if I format I will lose everything...and I have important data in the drive. How can I retrieve data and get the hard drive back to normal?
People often feel panic when I see this. If I format the drive, will I lose all my data? If not, how could I get access to my files?
My take is that you may have to format the drive (use quick format) and then use recovery software to recover your files.
Here's some information about file recovery, think you need to take a look, very useful
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
Sep 26, 2011 | Verbatim Portable, 500GB, USB, 5400rpm...
i have toshiba cavino 750gb hard drive. it was working fine since last night i can't open it.. it takes long time to open and i see format to paly it i don't want to loose my file i need some assistant
Don't be panic. you can try some format recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Aug 03, 2011 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
YES HOW HARD IS IT TO REFORMAT MY HARD DRIVE.
When you format a computer hard drive you will lose everything that is on the drive. Therefore, it is very important to back up anything you might want later. Additionally, if you are going to be formatting and installing XP you need to make sure you have the discs for any applications or third party hardware you use since you will need to re-install your programs and drivers after re-installing Windows. Step2Take a moment to think of anything that you have on the computer that you wouldn't want to lose. Generally, you probably want everything in your My Documents folder, and you also want to save things like your favorites or bookmarks from your Web browser. Remember that each user on the computer has his or her own My Documents folder, Desktop items and Favorites/Bookmarks. Step3Save everything to a CD, DVD or a hard drive that you won't be formatting Its pretty easy in other words
Dec 08, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
133 people viewed this tip
David Payne
David Payne
