Tip & How-To about Computers & Internet
CDlinux Guide for survival (Live Linux) CD USB flash
CDlinux is a live linux distribution,
You can use CDlinux as your “Mobile OS”.
The name is a synonymous of “Compact Distro Linux”.
1) How to put CDlinux on the CD.
1.a) Download CDlinux (Community)
http://cdlinux.info/wiki/doku.php/download/latest
1.b) CDlinux is distributed as an ISO image.
It is necessary to burn it to CD
using the option of your program to burn CDs
Burn CD ISO image (Windows - Nero / Burn Image to Disc, for example)
1.c) Then you need to restart your computer.
1.d) Depending on the options your motherboard,
it is necessary when starting
your computer keyboard press:
F8 or F12 or Esc, etc..
Thus you will appear a menu where you choose your CD drive.
After
CDlinux menu comes before you.
2) How to put CDlinux on a USB flash drive
2.a) Format the USB flash drive in the FAT32 filesystem. (Windows)
(MyComputer, right click on your USB flash drive, Format, File System = FAT32, start)
2.b) Boot CDlinux from the CD
Then
just use the GUI installation wizard.
Choose what you need.
Complete the installation process to end.
Restart your computer
Depending on the options your motherboard, it is necessary when starting
your computer keyboard press: F8 or F12 or Esc, etc..
Thus you will appear a menu where you choose your USB flash drive.
After
3) You can start using your CDlinux easily.
Computers & Internet Logo
detecting but unable to perform any action..
if you have a linux distribution at all (eg Ubuntu, Fedora) or download a linux distro and use a live version (which is smaller than full version and can be ran off a usb so switch your machine to boot to usb once distro is on there) then you should be able to see the hard drive on a linux distro all fine with all files still on there. Also another option is get a virtual box program and open linux from that and access your files in that virtual distro
Dec 01, 2013 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
boot from usb
Introduction UNetbootin allows you to create bootable Live USB drives for Ubuntu, Fedora, and other Linux distributions without burning a CD. It runs on Windows, Linux, and Mac OS X. You can either let UNetbootin download one of the many distributions supported out-of-the-box for you, or supply your own Linux .iso file if you've already downloaded one or your preferred distribution isn't on the list.
Requirements
  • Microsoft Windows 2000/XP/Vista/7, or Linux, or Mac OS X 10.5+. Note that resulting USB drives are bootable only on PCs (not on Macs).
  • Internet access for downloading a distro to install, or a pre-downloaded ISO file
Features UNetbootin can create a bootable Live USB drive, or it can make a "frugal install" on your local hard disk if you don't have a USB drive. It loads distributions either by downloading a ISO (CD image) files for you, or by using an ISO file you've already downloaded.
The current version has built-in support for automatically downloading and loading the following distributions, though installing other distributions is also supported:
Oct 15, 2011 | Microsoft Computers & Internet
Can't Reformat Kingston DataTraveler 2.0 USB memory stick
Use any linux bootable distro, like puppy (100 MB ) Slax ( 200 MB) or ubuntu to make a live boot, or use any pc which has linux installed can format your USB to its full capacity.
Apr 20, 2009 | Electronics - Others
Retuning to linux
I would say go with what is comfortable. Apparently the distribution that came with your PC was Xandros. Although I haven't used that particular distribution, I can say that Fedora and Ubuntu have really good support through the community and are just a quick download away.
Jun 23, 2008 | ASUS Eee 4G Notebook
948 people viewed this tip
David Payne
David Payne
