Tip & How-To about Bosch HBL 5052 Electric Double Oven
Bosch HBN13M250B/01 not heating or fan is not turning, common faults.
For all Free Bosch appliance repair videos visit our VIDEOTUTORIALS
A fan oven that has stopped heating up is probably the mostcommon oven fault that professional engineer is called to. The cause inmost cases is simply a faulty fan oven element. To employ the services of arepair company is going to cost you in the region of £60 - £100 to complete thejob.
With a little time, though and our FREE fan oven element video itshould take less than half an hour to repair, and the element can be purchasedfrom us for as little as £20 ! Why not Save yourself some money and read on
1, If the Bosch fan motor in the back of the oven isgoing round and the temperature light is on (normally little red light), butthere is no heat then you will probably need a new oven element, these aregenerally very easy to fit and readily available from our website these can betested with a electric meter.
To gain access to the Bosch element you will haveto remove the back plate from inside the oven. Once removed you will see the Boschfan and element, if you look closely at theBosch element you will probablysee a small hole burnt in it where it has blown. Sometimes however there is noevidence of a fault but the element is open circuit ie: brokeninside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If your Bosch fan oven is getting warm but takes a very long time tocook or is burning the food more on one side than the other, then you need tocheck if your oven fan motor is workingyou will see the blade turning fast if it is ok. if the element is heating butthe fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
3. If you have the opposite problem ie: your ovenis over heating and burning everything then you will need to replace your Bosch oven thermostat
4, A quite common and easily overlooked answer isif your oven is not working atall ie: no heat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
Bosch HBL 5052 Electric Double Oven Logo
How to replace thermostat for Tricity Bendix BS621B buit-in oven
this video should help
A fan oven that has stopped heating up is probably the most common oven fault that professional engineer is called to. The cause in most cases is simply a faulty fan oven element. To employ the services of a repair company is going to cost you in the region of £60 - £100 to complete the job.
With a little time, though and our FREE fan oven element video it should take less than half an hour to repair, and the element can be purchased from us for as little as £20 ! Why not Save yourself some money and read on
1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the Bosch element you will have to remove the back plate from inside the oven. Once removed you will see the Bosch fan and element, if you look closely at the Bosch element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your Bosch fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your Bosch oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Ovens
Oven will not heat up
Forall Free appliance repair videos visit our VIDEOTUTORIALS
1, If the fan motor in the back of the oven isgoing round and the temperature light is on (normally little red light), butthere is no heat then you will probably need a new oven element, these aregenerally very easy to fit and readily available from our website these can betested with a electric meter.
To gain access to the element you will haveto remove the back plate from inside the oven. Once removed you will seethe fanand element, if you look closely at the element you will probablysee a small hole burnt in it where it has blown. Sometimes however there is noevidence of a fault but the element is open circuit ie: brokeninside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If your fan oven is getting warm but takes a very long time tocook or is burning the food more on one side than the other, then you need tocheck if your oven fan motor is workingyou will see the blade turning fast if it is ok. if the element is heating butthe fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
3. If you have the opposite problem ie: your ovenis over heating and burning everything then you will need to replace your oven thermostat
Jun 14, 2009 | Bosch Ovens
958 people viewed this tip
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
