Tip & How-To about Office Equipment & Supplies
How to install Ricoh printer with downloaded driver
Well you do not need to return the printer because the files you have downloaded are drivers just they are installing on other way.
If you follow the explanation in the text below it will be very easy.
First as you say i think that you had already unzip the .exe file or if you did not follow the next steps:
1. Create one folder on the desktop named as you want or as the name of the printer for you after easy to find it.
2. double click on the " r41337en.exe " file that you had downloaded from the web site and click browse to find the folder that you had previously created on your desktop when you will locate the folder click unzip and after the message "successfully unzipped files " close the self executing program and see do in the folder are some files if there are some files, continue with the next step.
3. Click on the " Start " menu,
from the desktop in the left down corner,
and then click on "devices and printers"(doubleclick)
4. One window will open and than in the upper left corner you will find "add printer", click that button and it will appear a "add printer wizard" , click twice on the button "next" and select up the port you will use for the printer (do it will be a USB connection or with network cable is up to yours notion)and after you will select the type of connection click "next" again.
5. On the wizard on the right side has a button named "have disc" click on it,
it will appear window named " install from disc " than click the button named "browse" and then browse the folder which you had previously created on the desktop, in which you had unzip the files for the printer installation.
6. When you will locate the folder click on it with double click, then will apper folder named " DISC 1" click and on it with double click and then will appear file named " PCL6.INF " click on the file with double click ,
7. Then will appear a window named,
" install form disc" click on the button "OK" ,
then click on the button "next" three times and then click "Finish "
That is all the printer is now installed and ready for use.
Please answer do this was helpful for i to know do i need to post some more information
If you need something else please ask
Regards
need software disk to i nstall printer
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Nov 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
need to connect a z1300 lexmark printer to asus laptop
You need to install the software from printer disk before connecting printer USB to the laptop.
Apr 14, 2009 | Lexmark Z1300 InkJet Photo Printer
need to download driver for lexmark z600 printer
Z600 is the series, the printer will be something like Z601, Z605 etc.
If you do not know the model, download Z601.
You need to follow instructions below, as direct link to printer page is not available.
Note:some printer does not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Mar 25, 2009 | Lexmark Z600 InkJet Printer
We have a lexmark 1240 for windows xp and need to install it
You need to install driver that support Windows Vista,
so download your driver from below link>>
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Note: Install the driver after downloding.
please rate this solution.
Thanks for using FixYa.
Feb 14, 2009 | Lexmark X1240 All-In-One InkJet Printer
Hi I have a hp 1317 psc all in unit old yes but it was working well. Couple of days ago computer crashed and had to returned to factory settings. Have tried now for a couple of days to reinstall the printer but without success. I do not have a the start up disc any longer Could you please help me on this matter. Thanks keith Allison
Click here:Official Hp PSC Drivers and Software
or click directly here
s.gif gc_w01_ENU.exe, (1/1 , 364.59M)
Awebpage will open, follow instructions, select model, then operativesystem etc.,go to next page twice, find file, and click on download .
Afterdownloading,findthefile,double click on the file with the mouse, ifyou get introubles,then follow instructions below to reset andreinstall:
  • Download driver from website and run the file.
Note:this printer does not work on Vista you can only install it on Windows XP.
Oct 10, 2008 | HP Office Equipment & Supplies
5,144 people viewed this tip
k24674
jasbo
jasbo
