Tip & How-To about Cameras
Lubrication of small, delicate items having plastic or aluminum hinges
Lubrication of small, delicate equipment
When working on cameras, laptops, and any equipment that is in need of
some lubrication, where the joint is made of plastic or aluminum, instead of using oil or petroleum based products, use instead silicon lube that is packaged in a spray can. Look for the smaller sized can because this will allow easier (or even possible) access to the area that needs the lube. You will find that the extender tube that comes with the can to be the best way to get the lube focused into the area that needs the lubrication, and not make a mess by getting it where not needed.
If you need more reach than the tube that comes with the can provides, you can extend it by using small shrink tubing. First put the can's tube into the spray nozzel, then extend it with the shrink tubing. If you do get it where not needed it will clean up without smearing and leaving a difficult film on the surface. If on a lens, use isopropy or pure alcohol, then the lens cleaner.
Cameras Logo
does my Buick LeSabre 1992 have chassis lubrication points?
lubrication points will be ball joints and "U" joints
I suggest that to enable you to successfully find all the points, that you have the local mechanic do the job and while he is at it to point out the locations to you so that next time you can do it your self
Aug 08, 2015 | 1992 Buick LeSabre
routine lubrication
Lubricating...
Some sewing Machines w/computer is equipped with a
LM (low mass) hook system which requires no
lubrication. But...
HINT*** If however you do lubricate any parts, always
run the sewing computer immediately afterwards
on scrap material to avoid soiling your work!!!
Apr 11, 2015 | Sewing Machines
What are oil lubricators?
Industrial lubricants market is full of options today. From a variety of automotive & industrial lubricants and specialty products & lube additives, all kinds of lubrication needs are met here. Oil lubricator is a unique blend to enhance performance of the machine & equipment's.
Sep 18, 2014 | Health & Beauty
Are there front-end grease joints that need lube periodically or are they sealed and don't require fresh grease?
There are places to lubricate the joints and such in the front end. The ball joints certainly have lube points if nothing else does. Anything that could be metal to metal contact needs periodic lubrication. Check your owners manual for Lubrication types. Most are using a molediumdysulfide based lubricant in the newer vehicles. It is easily available at Walmart and most auto parts stores. Just don't use a graphite based Lube unless it is specifically called for. If your owners manual is short on information on this you should pick up a Haynes repair manual on your vehicle. It will specify lube points and intervals and what type of lubrication to use.
Jul 24, 2010 | 2004 Toyota Sequoia
2000 Silverado L/T Z71 4X4 Lubrication Diagram
Lube points should be: All moving joints in suspension. Ball joints, idler arm, tie rod ends etc. On 4X4's, all universal joints on drive axles (excluding C/V joints... just inspect boots) All slip-joints and "u" joints on driveshafts. Many of these items may not have zirk fittings on them from the factory. If the component has a plug installed, it should be removed & replaced with a fitting. If there is no place for a fitting, when the item wears out, the replacement will have a fitting.
Sep 13, 2008 | 2000 Chevrolet Silverado
6,323 people viewed this tip
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
