Tip & How-To about Lexmark E120n Laser Printer
Solution
If LED ! glow all time it's problem with chip it's need to be replace!!
Lexmark E120n Laser Printer Logo
my cpu green led is glowing but monitor screen is black and keyboard led is continue glowing
There are No display in your system .Pls remove Power cable from CPU and again plug it and start your system.If display still not comes then pls remove RAM chip from slot in the Motherboard and re-install goods one and check it.if still display not come then issue with Motherboard .Its detter call vendor for repair the Motherboard.
Nov 19, 2009 | Intel Motherboard
No image on monitor
Looks like the Video card, or Video chip has bought the farm
Try hooking up to another monitor to confirm where the problem is.
Jan 30, 2009 | ViewSonic VX922 19" Monitor Flat Panel
canon mp160 empty cartridges
THERE IS NO WAY TO RESET THE CARTRIDGES"S CHIP SET TRY IGNORE IT.
Nov 21, 2007 | Canon PIXMA MP160 All-In-One InkJet...
TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Jun 25, 2007 | Philips 27PT81S 27" TV
2,100 people viewed this tip
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
