Tip & How-To about Computers & Internet
Control Center Ubuntu
1) Gnome Control Center is the front end configuration applet
(capplets) which allows you to configure your GNOME desktop.
2) Appointed by the depth of the command interface, so that
it is not just easy to find in the Ubuntu-in.
3) Control Center will give you a merged
able to easily configure your Ubuntu
In a similar way as in Control Panel in Windows.
(1.A) The first way:
The upper panel
mouse pointer is positioned
Above System
Right click
the drop-down menu, left click on
Edit Menus
in a new window on the left side
left click on
System
the right side, check in Control Center
Close our window.
Then, left click on System and we got the opportunity to run the Control Center.
(1.B) The second way:
System> Preferences> Main Menu
Close our window.
(1.C) The third way:
Press the keyboard
Alt + F2
in a new window
type: alacarte
then left click
Run
Close our window.
(1.D) Now you have easy access to a control center in Ubuntu.
Computers & Internet Logo
Has anybody configured Reliance Datacard - USB on ubuntu 9.04? Kindly give me step by step procedure for configuration? Regards, Moiz
First use the following command to see if your card is being detected by kernel.
cat /proc/bus/usb/devices
Then you can use the following script for the installation, you can check if this is for your version of Ubuntu.
#!/bin/bash
#This program automates task of setting up connection for Reliance USB Card on Ubuntu Hardy Heron. This program does not come with any warranty whatsoever. Please use it at your own risk.
# Detect Modem
echo "Modem Detected: $(lsusb | grep -i huawei | cut -d" " -f7-)"
# Get Connection Number from User
echo "Enter Your Reliance Data Card Connection Number : "
read connection
echo "Setting up connection with $connection"
#Install Gnome PPP Package
echo "Installing Required Packages.."
sudo apt-get install -y -q gnome-ppp wvdial
#Add entries to /etc/ppp/ppp-secrets and /etc/ppp/chap-secrets
echo "I:Modifying necessary system files to allow dialing with Gnome PPP..."
sudo chmod 666 /etc/ppp/pap-secrets /etc/ppp/chap-secrets
echo "$connection * $connection" >> /etc/ppp/pap-secrets
echo "$connection * $connection" >> /etc/ppp/chap-secrets
sudo chmod 600 /etc/ppp/pap-secrets/etc/ppp/chap-secrets
#Start Gnome PPP
echo "We are all set.... "
echo "Starting Dialer..."
gnome-ppp &
exit 0
Dec 10, 2009 | Computers & Internet
tht sims bustin out game playstation 2
Hi clinnane,
Try these>
During game-play press pause and enter the following codes. The Gnome cheat
Must be entered first for these cheats to work
Gnome Cheat:
R2, L1, R1, L2, Left, Circle
Note: If a cheat is not allowed a Gnome will appear on the Sim's property to
Signify this. You can click this Gnome for money.
Unlock All Socials:
L1, R1, Down, X, L3, R3
Unlock Team Photos:
L3, R3, R1, R2
Unlock All Skins:
L1, R2, X, Circle, Up, Down
Fill Motives:
L2, R1, Left, Circle, Up
Unlock All Locations:
R2, R3, L3, L2, R1, L1
Unlock All Objects:
L2, R2, UP, Triangle, L3 Happy gaming :)
Sep 23, 2008 | Sony PlayStation 2 Slimline Console
volume&thinkpad button
Most IBM / Lenovo Thinkpads have hardware volume control with apropriate buttons above the keyboard (volume up, down and mute). Gnome in Ubuntu is configured in such a way, that the keypresses are trapped (this is correct), apropriate volume window is displayed (correct) and Gnome volume control is modified. Last step is actually wrong - the keys in Thinkpads control the volume hardware directly, so every keypress turns the volume up/down regardless of sound card settings (in Ubuntu case - this would be Alsa mixer). Current behaviour results in volume being changed twice - for example if I press the volume up button, I get volume reduction via Gnome sound mixer plus volume reduction via hardware control. Effectively this creates an exponential (and not linear as it should be) volume change. In short - it is very difficult to control volume, especially relatively quiet sounds, with volume keys only.
The "patch" solution is to decouple Gnome mixer from hardware buttons. Of course it could be done manually, by deleting apropriate key actions in System->Preferences->Keyboard shortcuts, but this also disables windows showing volume. A better thing (but more complex) would involve reading /proc/acpi/ibm/volume and displaying the volume window according to this value at each volume button keypress.
I tested this on T21, T42 and Thinkpad 600. I guess only some R series notebooks (R31 etc.) would not be affected, as these do not have hardware mixer.
Steps to reproduce:
1. Press hardware volume key (eg. volume up) on a Thinkpad
2. Observe the volume change - it is changed in hardware mixer (correct) and in Gnome volume control (incorrect)
I hope this helps...
Apr 18, 2008 | IBM ThinkPad R31 2656 Notebook
272 people viewed this tip
David Payne
David Payne
