Tip & How-To about Computers & Internet
How to Solve " Registry Editing has been disabled by your Administrator"
Methods to Remove the Registry Editing Restriction
Method 1 :- Using REG.EXE Console Tool
  • Click Start, Run and type this command
REG add HKCUSoftwareMicrosoftWindowsCurrentVersionPoliciesSystem /v DisableRegistryTools /t REG_DWORD /d 0 /f
You should be able to launch Tweak UI, as well as the Registry Editor.
Method 2 :- Using the Group Policy Editor (Windows XP Only)
  • Click Start, Run and type gpedit.msc and press Enter
  • Goto the following location User Configuration | Administrative Templates | System
  • Double-click Disable Registry editing tools and set it to Not Configured
  • Exit the Group Policy Editor
Note:- If the setting already reads Not Configured, set it to Enabled and click Apply . Then revert it back to Not Configured. This ensures that the DisableRegistryTools registry value is removed successfully.
Computers & Internet Logo
YahooMessenger.exe-Aplication Error The application failed to initialize properly [0xc0150002].Click on OK to terminate the application
Try to remove yahoo messenger and re-install it again.
If you can't uninstall it try this:
1) Log out of Yahoo Messenger and close yahoo messenger completely [ it should not be running under task manager as a process ]. 2) Open Start Menu >> Control Panel. 3) Double-click on Add or Remove Programs. 4) Locate Yahoo Messenger in Add or Remove Programs. 5) Click Change/Remove button. 6) Restart your computer, if it doesn't restart it automatically. 7) Open Yahoo folder in Program Files (C:\Program Files\Yahoo) and delete it. 8) Open registry through Start Menu >> Run and type regedit now navigate to the HKEY_CURRENT_USER\ Software\ registry entry, delete Yahoo, and exit the Registry.
If the above method does not work for you, try the following methods to solve the problem.
1. Open Program Files >> Yahoo Messenger and find the file UNWISE.exe file. Double click this to run it. This will un install yahoo messenger.
Jun 27, 2011 | Yahoo Messenger
how to enable control panael,taskmanager
Method 1 - Using the Group Policy Editor in Windows XP Professional
  1. Click Start, Run, type gpedit.msc and click OK.
  2. Under User Configuration, Click on the plus (+) next to Administrative Templates
  3. Click on the plus (+) next tSystem, then click on Ctrl+Alt+Delete Options
  4. Find Remove Task Manager in the right-hand pane and double click on it
  5. Choose the option "Not Configured" and click Ok.
  6. Close the Group Policy Window
Method 2: Change the Task Manager Option through the Run line
  1. Click on Start, Run and type the following command exactly and press Enter
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableTaskMgr /t REG_DWORD /d 0 /f
Method 3: Change Task Manager through a Registry REG file
  1. Click on Start, Run, and type Notepad and press Enter
  2. Copy and paste the information between the dotted lines into Notepad and save it to your desktop as taskmanager.reg
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
3. Double click on the taskmanager.reg file to enter the information into the Windows registry
Method 4: Delete the restriction in the registry manually
  1. Click on Start, Run, and type REGEDIT and press Enter
  2. Navigate to the following branch
    HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
  3. In the right pane, find and delete the value named DisableTaskMgr
  4. Close the registry editor
For Control Panel
Start | Run | Type: gpedit.msc | OK |
Navigate to >>>
User Configuration\Administrative Templates\Control Panel\
Prohibit access to the Control Panel
[[Disables all Control Panel programs.]]
Jan 12, 2010 | Microsoft Windows XP Home Edition
how to enable registry editing
Method 1 - Using Group Policy Editor If you are using an edition of Windows Vista (Windows Vista Business, Enterprise and Ultimate editions) which includes the Group Policy Editor, follow these steps:
  • Click Start, type gpedit.msc in the Search box, and press ENTER
  • Go to the following branch:
  • Double-click Prevent access to registry editing tools
  • Set it as Not Configured
Important: If it's already set to Not Configured, set it to Enabled and click Apply. Then repeat the steps and revert the setting back to Not Configured. This removes the registry based policy if set already.
Method 2 This method should work in all editions of Windows Vista.
  • Download reg_enable.vbs attached at the end of this article, and save it to Desktop
  • Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  • Switch to your Desktop directory by typing the following command, and then pressing ENTER:
cd /d %userprofile%\desktop
  • Then, type the following command and press ENTER
wscript.exe reg_enable.vbs
  • Type EXIT to close the Command Prompt window.
If everything worked fine, the DisableRegistryTools policy should have been removed by now. See if you're able to launch Regedit.exe now.
Dec 11, 2008 | Microsoft Windows XP Professional
desktop properties (desktop and screensaver tab is missing)
The following is solved me
Well if anyone is interested and for general knowledge these are the 3entries that were killing the Desktop and Screen Saver tabs in XP. Hupigon13 seems to be at the root of it all.
Quote: Microsoft.Windows.System: Settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispBackgroundPage!=W=0
Microsoft.Windows.System: User settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispScrSavPage!=W=0
Hupigon13: Settings (Registry value, fixed)
HKEY_LOCAL_MACHINESYSTEMControlSet001ServicessrImagePath=...SystemRoot...
Read full story here
http://forum.osnn.net/showthread.php?s=f44e1bb094fbae9305c9f0c9999c52e7&p=841430#post841430
Jul 16, 2008 | A4tech PK5
hide task manager
hi dear
start menu, run
type regedit
find this....
change dword to 000000000
oke
Mar 19, 2008 | Microsoft Windows XP Professional
318 people viewed this tip
David Payne
David Payne
