Tip & How-To about Computers & Internet
Common FTP Error Codes
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy - mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
120 Service ready in nnn minutes.
125 Data connection already open; transfer starting.
150 File status okay; bout to open data connection.
200 Command okay.
202 Command not implemented, superfluous at this site.
211 System status, or system help reply.
212 File status.
213 File status.
214 Help message. On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type. where NAME is an official system name from the list in the Assigned Numbers document.
220 Service ready for new user.
221 Service closing control connection.
225 Data connection open; no transfer in progress.
226 Closing data connection. Requested file action successful (for example, file transfer or file abort).
227 Entering Passive Mode (h1, h2, h3, h4, p1, p2).
230 User logged in, proceed. Logged out is appropriate.
250 Requested file action okay, completed.
257 "PATHNAME" created.
331 User name okay, need password.
332 Need account for login.
350 Requested file action pending further information.
421 Service not available, closing control connection. This may be a replay to any commend if the service knows it must shut down.
425 Can't open data connection.
426 Connection closed; transfer aborted.
450 Requested file action not taken.
451 Requested action aborted. Local error in processing.
452 Requested action not taken. Insufficient storage space in system. File unavailable (e.g., file busy).
500 Syntax error, command unrecognized. This may include errors such as command line too long.
501 Syntax error in parameters or arguments.
502 Command not implemented.
503 Bad sequence of commands.
504 Command not implemented for that parameter.
530 Not logged in.
532 Need account for storing files.
550 Requested action not taken. File unavailable (e.g., file not found, no access).
551 Requested action aborted. Page type unknown.
552 Requested file action aborted. Exceeded storage allocation (for current directory or dataset).
553 Requested action not taken. File name not allowed.
Computers & Internet Logo
unable to compose, reply, or forward in Yahoo Mail for the last 2-3 days
The inability to send, reply, or forward emails could be from a program that was installed on your computer that is now preventing the Yahoo! Mail Rich Text toolbar from launching properly. Try switching from "Rich Text" compose mode to "Plain Text" as a work around:
  1. Sign in to your Yahoo! Mail account.
  2. Click the New button to start a new email.
  3. To the far right of the "Subject" line click the "Plain Text link.
  4. Compose and send your email.
To make "Plain Text" your default when replying or forwarding, do this:
  2. Click "Options," then select "More Options" from the pull down arrow in the upper right corner of your Mail page.
  3. Select "General" from the list of options on the left side of the page.
  4. Check the box next to; When replying & forwarding Mark original message with > (plain text only).
  5. Click the "Save Changes" button in the upper left corner.
Aug 17, 2011 | Yahoo Mail
Just want to know what the texting icon means. One has a check mark and one has an arrow pointing upward.
that usually means that you've done two different actions with the texts... the one with the check, means you only read it... the one with the arrow, means you replied or forwarded it
Mar 19, 2010 | Verizon Communications enV2 Cellular Phone
Hello i want to use h LOOK UP
Hi !!
How to implement Hlookup function:
  • Select your data and sort it in ascending order
  • Then type '=HLOOKUP(lookup_value,table_array,row_index_num,range_lookup)'.
    Lookup_value is the value to be found in the first row of the table. Lookup_value can be a value, a reference, or a text string. Table_array is a table of information in which data is looked up. Use a reference to a range or a range name. The values in the first row of table_array can be text, numbers, or logical values. If range_lookup is TRUE, the values in the first row of table_array must be placed in ascending order: ...-2, -1, 0, 1, 2,... , A-Z, FALSE, TRUE; otherwise, HLOOKUP may not give the correct value.
    If range_lookup is FALSE, table_array does not need to be sorted. Uppercase and lowercase text are equivalent. You can put values in ascending order, left to right, by selecting the values and then clicking Sort on the Data menu. Click Options in the sort dialog box, click Sort left to right, and then click OK. Under Sort by, click the row in the list, and then click Ascending.
    Row_index_num is the row number in table_array from which the matching value will be returned. A row_index_num of 1 returns the first row value in table_array, a row_index_num of 2 returns the second row value in table_array, and so on. If row_index_num is less than 1, HLOOKUP returns the #VALUE! error value; if row_index_num is greater than the number of rows on table_array, HLOOKUP returns the #REF! error value.
    Range_lookup is a logical value that specifies whether you want HLOOKUP to find an exact match or an approximate match. If TRUE or omitted, an approximate match is returned. In other words, if an exact match is not found, the next largest value that is less than lookup_value is returned. If FALSE, HLOOKUP will find an exact match. If one is not found, the error value #N/A is returned.
  • If HLOOKUP can't find lookup_value, and range_lookup is TRUE, it uses the largest value that is less than lookup_value.
  • If lookup_value is smaller than the smallest value in the first row of table_array, HLOOKUP returns the #N/A error value.
  • If range_lookup is FALSE and lookup_value is text, you can use the wildcard characters, question mark (?) and asterisk (*), in lookup_value. A question mark matches any single character; an asterisk matches any sequence of characters. If you want to find an actual question mark or asterisk, type a tilde (~) before the character.
  • In the example in the Excel training video the sorted data represents the density of water at different temperatures. The left most column gives the temperature in degrees and the top column specifies the 'decimal' degrees
  • We looked up the density of water at 5.4 degrees celsius using the Hlookupfunction.
Still have problems, Check this video on the you tube.
Hope this would help,
Thanks,
Anurag Shukla
Sep 04, 2009 | Microsoft Excel for PC
Unable to Change Dates
I am using MS-2007, i got the solution upto some level only.
i can't say exactly whether it is right or not.
my solution is :
first change the settings in ControlPanel/Regional and Language Options.
Click on Customize button/open the Date Tab and set the date format there.
and then proceed with CSV.
Open CSV in Excel and divide Text to coloumns.
Ur all Date Cells will be in particual Format.
and Select that coloumns and right click Format Celss....etc.
Thanking u.
If u found any Douts, Suggestions ,Plzz let me know.
Jun 27, 2008 | Excel (SS8SATAS5128400R)
171 people viewed this tip
David Payne
David Payne
