Tip & How-To about Cell Phones
NOKIA SECRET CODES *#06# To check the IMEI. *#0000# To check the firmware version and date. *#92702689# *#war0anty#. To check the IMEI. The date when it was purchased, and the date when it was repaired. *4720# (*hra0#) To activates th e Half Rate. #4720# (#hra0#). To deactivates Half Rate. *3370# (*efr0#). To activates Enhanced Full Rate. #3370# (#efr0#). To deactivates Enhanced Full Rate. *#746085685# . (*#sim0clock#) To check the SIM clock status. *#7220# (*#pca0#) To activate the GPRS and Packet Common Control Channel PCCCH) supports. *#7230#. (*#pcd0#) To deactivate the GPRS and Packet common control channel (PCCCH)supports. *#7760# (*#ssn0#) To check the manufacturing serial number. *#2820# (*#bta0#) To check the Bluetooth MAC address. *#7370925538#. (*#res0wallet#) Reset the mobile wallet.
Cell Phones Logo
how to get security code of asaha 303
Dial using the keypad: * # 0000 # - the version number displayed on the display.
V 5.16
22-06-99
NSM-1
V 5.16 - software version
22-06-99 - date
NSM-1 - The hardware (model)
View IMEI
Dial using the keypad: * # 06 # - IMEI number is displayed on the display.
SimClock
Allows you to check whether your SIM-card mode StopClock. When transferring the card to this mode significantly reduces power consumption and thus increases the work of the battery. Generally, all modern SIM-cards support this mode.
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display (operator logo).
*#0000# To view software version.
*#2820# Blue tooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that support WLAN
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Code activation.
*#4720* - Half Rate Code deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin#
*#7328748263373738# resets security code.
Default security code is 12345
SIM Clock
Stop allowed
Warranty Codes
* # 92702689 # [* # war0anty #]
Dec 29, 2014 | Cell Phones
my imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
HI
PZL TRY THE FOLLOWING
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
*#92702689# [*#war0anty#]
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+4# for SimCard-Lock status
# = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Sep 21, 2011 | Nokia 3110 Cellular Phone
nokia new models secret codes
View the firmware version of the phone
V 5.16
22-06-99
NSM-1
22-06-99 - date
View IMEI
SimClock
SIM Clock
Stop allowed
Warranty Codes
Enter the menu of warranty codes. In fact, you do not need, but you can find them using the arrows scroll menu.
Menu:
1. Shows the serial number of the device.
2. Date and year of manufacture (eg 0299).
3. Shows month and year of sale (if installed). Here you can set the date, but be careful - it can be done only once in their life phone
4. Date of last repair (if any)
5. Sends all the phone numbers, pictures, and calls from one phone to another (possibly in order to restore). In models with an infrared eye, this procedure works, and through him
EFR CODEC (Enhanced Full Rate)
This function with its inclusion on the idea, should significantly improve the quality of speech, but unfortunately, it must be supported by your connection. When the work is slightly increased power in the phone call (about 5%). How do I know, none of the Russian cellular operators do not support this feature. Principle is based on a different compression algorithm for speech recognition (ACELP) and has a wider bandwidth.
Feb 28, 2011 | Nokia E71 Smartphone
all code sent my email
V 5.16
22-06-99
NSM-1
22-06-99 - date
View IMEI
SimClock
SIM Clock
Stop allowed
Warranty Codes
Menu:
1.Shows the serial number of the device.
2.Date and year of manufacture (eg 0299).
3.Shows month and year of sale (if installed). Here you can set the date, but be careful - it can be done only once in their life phone
4.Date of last repair (if any)
5.Sends all the phone numbers, pictures, and calls from one phone to another (possibly in order to restore). In models with an infrared eye, this procedure works, and through him
Dial * 3370 # to activate (the phone should reboot) or # 3370 # to deactivate this function.
HR CODEC (Half Rate)
Substantially impairs the quality of speech, but saves battery somewhere at 30%. Again, must be supported by a mobile operator. American networks that support this feature, I do not know.
Dial * 4720 # to activate (the phone should reboot)
or # 4720 # to deactivate this function.
i hope this helpful
thank you for using fixya
Feb 09, 2011 | Nokia 5230 Cell Phone
please help.,.,i need my license key.,., imie 35227201819836.,., thanks
insert code :
and
like this example :
V 5.16
22-06-99
NSM-1
22-06-99 - date
View IMEI
i hope this helpful
Feb 07, 2011 | Nokia 6600
171 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
