Tip & How-To about Washing Machines
How to Level a Whirlpool Top Loading Washer.
If you are experiencing consistent off-balance load issues with your Whirlpool top loading washer, it may be caused by a simple problem of needing to reset the auto-level mechanism and making sure the front feet are properly level. This advice may save you a service call and restore an unbalanced washer to running condition.
The rear feet on Whirlpool manufactured top loaders have an auto-leveling mechanism that you can easily reset yourself. Just follow these steps:
1. With the wash tub empty, open the washer lid and grasp the rim of the tub opening (do not grab the tub).
2. Now place one of your feet at the base of the washer along the front of the washer to keep it from moving.
3. Now pull the washer towards you so the rear feet lift off the floor a couple of inches. You should hear a clicking sound as the rear feet auto-level.
4. Carefully set the washer back down (do not slam it) and the rear of the washer should now be level.
Using a level, check the washer front to back and side to side to make sure it is level in all directions.
If you need to adjust the washer washer front feet, carefully lift the front of the washer and turn the feet to either adjust them up or down. The slightest difference can cause excessive vibration on the final spin. Check by placing your hands at opposite corners on top of the washer (diagonally - one on the rear, one on the front) and try rocking the washer to see if it moves. If the washer wobbles, you need to readjust.
This advice is for all Whirlpool manufactured top loaders with a direct-drive system such as Kenmore, Estate, Kelvinator, Roper, and Frigidaire. If in doubt, please post your MODEL NUMBER when submitting questions, so that I can determine if your washer is configured with this feature.
This does NOT include the Oasis, Cabrio or Calypso models.
I hope everyone finds this information helpful.
Washing Machines Logo
Whirlpool Thin Twin model LTE5243DQ2 The washer will pump the water out but it wont spin unless i open the machine and rearrange the load. Then it spins but sounds like it's working very hard to do so
I'm not familiar with your model but on the surface it sounds like the belt is loose. If the load is not really well-balanced, a loose belt can't move the drum and when the load is balanced the motor turns really fast because the belt is slipping. Tightening or replacing the belt is fairly simple with normal tools and there are plenty of pages/videos out there on how to do it. Hope this helps! Good luck!
Apr 05, 2014 | Whirlpool LTE5243D Top Load Stacked...
WHat is the capacity of the Whirlpool LLR9245BQ1 top load washer?
Hello there
  • Washer Type: Washer
  • Load Type: Top Load
  • Volume Capacity: 3.2 cu/ ft
is one of the better, super-sized porcelain-on-steel wash basket, combined with the Xtra roll action plus agitator, which ensures that your really big loads get really clean! The dual action of the Xtra Roll Action Plus agitator rolls even huge loads to the bottom of the wash basket where cleaning takes place. It can effectively roll over and clean twice the average size load! Plus, wash fewer loads to save time, money and energy! Ultimate Care washers offer both five and six speed combinations providing flexibility for the future in fabric care. Plus, the easy-to- use consoles makes it simple to select the desired wash/spin speed combination. And the enhanced agitator vanes ensure clothes roll over for consistent cleaning -
Jan 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
missing balance ring clips on whirlpool washer model # LXR9445JQ0
just buy the clips, watch a video to remove the housing of the washer. it is a simple fix. should be below $20 to get the clips, j
http://www.partselect.com/PS874751-Whirlpool-3956205-Balance-Ring-Top-of-Inner-Tub-White.htm?SourceCode=1&SearchTerm=LXR7244JQ1&ModelNum=LXR7244JQ1#Instructions
Jul 15, 2010 | Whirlpool LXR6432JQ Top Load Washer
washer dial problem on whirlpool LSB6000PQ
HI, This will occur when the timer mechinism(washer dial) has failed. The main cause of this type of failure will be timer motor breakdown. The timer motor is essential to the sequential balance of the cycle that is selected. If it is unable to rotate the dial properly, it will not allow the unit to operate correctly.
Replacing the timer module will correct this issue you are experiencing at this time.
Sep 11, 2009 | Whirlpool LSB6000PQ Top Load Washer
Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
5,047 people viewed this tip
Top Washing Machines Experts
