Tip & How-To about Apple PowerBook G4 Mac Notebook
LCD Display Problems with Apple 15" PowerBook G4 Aluminum 1.25 GHz Mac Notebook
During boot-up, Apple logo heavily pixelated. After boot-up, display a riot of colors and vertical lines with nothing readable. External monitor works well
I'll appreciate any input.
~ JO
Apple PowerBook G4 Mac Notebook Logo
they are flashing vertical lines in various colors as well as letters showing
hook an external monitor. if its the same problem, video card is the problem. if it has a clear display, then you need to replace the lcd.
Apr 09, 2010 | Microsoft Windows XP Professional for PC
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Inspiron 8500 - Display issue
with the external monitor attached press <FN><F8> to toggle between internal and external display. if still nothing then it sounds like the video card.
MANUAL
Check all the connections (especially the ground screws) that was a problem with one I worked on last year.
May 29, 2008 | Dell Inspiron 8500 Notebook
LCD vertical lines
hi, all the LCD cable contact pins to be cleaned, if still invain then u will need to replace the LCD..
Mar 16, 2008 | Toshiba Libretto 100CT Notebook
Problems with Apple 15" PowerBook G4 Aluminum 1.25GHz LCD Display Mac Notebook?
The coonection on the(LCD AND LAPTOP IS BAD The wirng )You have to have it taken apart and fixed. I can do it if you live in California or ship it to me. But that is what the problem is.
Feb 07, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
1,846 people viewed this tip
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
