Tip & How-To about Microsoft Windows XP Home Edition
How to quickly shutdown your system?
Most of the time we may be fed up with the time taken for shutting down of the system, to shut down your system quickly just press the shutdown in the task manager while pressing down the control key..................you can see the difference yourself
Microsoft Windows XP Home Edition Logo
UNIT SHUTS DOWN FREQUENTLY
How soon after starting does it shut down?
The hour meter is fed directly from the AC output off the generator stator, if there is no AC output the meter will not run. Assuming it shutdowns quickly, check 1st the oil level and make sure the low oil sender unit is ok, wire #24 to ground. If that is bad it will shut down. Check to see if you have 240V on L1 and L2 on the breaker for the brief time it does start, that will confirm stator/rotor has an output, then your problem moves from the generator portion to either the oil sender, or control board.
Feb 24, 2013 | Powermate Coleman Standby Generator...
mid tablet wont shut down
So you need to be In the main menu interface then press the power button for about 5 seconds to shut it down. Below is the power section out of the manual.
1.2 POWER
startup: Long Press and hold the power button, the system will enter the main interface
shutdown: In the main menu interface, Press the power button about 5 second to shutdown, The system can hint "power off" option, Clike"ok". you can safely shut down.
Lock screen: Short press Power button to lock screen or unlock screen.
Remark 1.When power is empty,system will shut down automatically.
2.Illegal turn off the device,restart will scan and restore the disk,it may take longer time to enter into system
Jan 30, 2013 | mid Archos M729B Android Tablet
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
won't shut down completely
If shutting down XP takes what seems to be an inordinate amount of time, here are a couple of steps you can take to speed up the shutdown process:
  • Don't have XP clear your paging file at shutdown. For security reasons, you can have XP clear your paging file (pagefile.sys) of its contents whenever you shut down. Your paging file is used to store temporary files and data, but when your system shuts down, information stays in the file. Some people prefer to have the paging file cleared at shutdown because sensitive information such as unencrypted passwords sometimes ends up in the file. However, clearing the paging file can slow shutdown times significantly, so if extreme security isn't a high priority, you might not want to clear it. To shut down XP without clearing your paging file, run the Registry Editor (click Start > Run, then type regedit in the Run box) and go to:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
  • Change the value of ClearPageFileAtShutdown to 0. Close the Registry, and restart your computer. Whenever you turn off XP from now on, the paging file won't be cleared, and you should be able to shut down more quickly.
    Note: Please be careful when editing the Registry; you can do a lot of damage here. Don't change or delete anything unless you know exactly what it is.
Apr 13, 2009 | Computers & Internet
Computer shuts down.
Hello;
So i guess that the PSU is good. As i diagnose of what you have said, i digested a conclusion that when the computer shutdown when application run. there a problem conflicting the application to another application or such an application trigering the system to shutdown.
Some causes of this problem are:
The system is infected by known and unknown virus
The driver of the system are not properly installed
The application program committed an errors trigering the system to shutdown.
Possible solutions:
1. Scan you system with a potent anti virus
2. Remove the installed driver of the sytem and reinstall it after restarting
3. Unistall the application that causes shutdown problem and you can reinstall it after restarting.
4. remove newly installed hardware or install the correct driver of the hardware.
Note in scanning your system with antivirus you should scan it it safemode.
some usefull links: http://www.precisesecurity.com/antivirus/online-scan.htm
If all the solution did not work to your system. please notify me for further solution.
best regards, melnavz
Feb 20, 2008 | E-Machines W3052 PC Desktop
519 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
