Tip & How-To about Cell Phones
How To Unlock The Password Protected Memory Card For Your Mobile Phone when one my friend forgot the password of his memory card of his mobile phone and he have some very important data in the memory card which he want to recover, he tried almost everything then he lost hope and then asked the mobile phone company to find the way to recover the data from the memory card. But you don?t worry if you are having the same problem?as now there is a much simple and easy way out. Requirement: You need a file explorer like FExplorer which you can download from here. How to Unlock MMC card: Method 1: Insert card into your phone but don?t access it through phone. Run FExplorer and Open the path C:\system. You will find a file called mmcstore ,rename the file mmcstore.txt Copy that file(mmcstore.txt) to your pc and open that file in notepad. You will find your password in that file. Method 2: Applicable to all nokia phones which are s60 2nd or s60 3rd edition series phones.check out here. If you still have any problem in finding your password for your memory card ,leave a comment here.
Cell Phones Logo
i forgot my micro sd memory card password and it is password protected ... bit actually i have forgotton the password and now i'm using another phone ... in other phone the memory card is not open
Plz go to any mobile shop..ask him to unlock u'r memory card..within half an hour he will unlock u'r memory card by using card decoder..u'r memory will be formatted but u'r memory will be unlocked..Now download recovery software,with this u can bring u'r lost data back..
.."Do the new"..
Apr 01, 2013 | Nokia 6303 Cell Phone
I forgot my memory card password Nokia 5130, how can i unlock it? Help me please :((
Your can store your personal information or documentation of your mobile memory card. To protect your files or documents, you need to give a password on the memory card. It's a common mistake of human that most time they set password and forget that password. So, what to do then? Do you need to contact the mobile phone service center? It's a costly solution. Moreover, you have to spend enough time and effort to do that. All the peoples do their best to unlock the memory card and to recover the data. It's really a great annoying thing. But you can do it by yourself very easily. You just have to follow some steps to unlock your password protected memory card of your mobile phone. This page tells you the process of unlocking any password protected mobile memory card.
Steps to Unlock a Password Protected Memory Card of Your Mobile Phone
The steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, click here to download.
2. After finished downloading, install it to your mobile phone.
3. Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
4. Run FExplorer and open the following location C:\system.
5. From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
6. Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
7. When you finished the above steps, you will find the password of that file
Do your own risk..don't blame me try this links-
http://hubpages.com/hub/How-to-Unlock-a-...
http://www.mobilecubix.com
Apr 30, 2011 | Cell Phones
I forgot my memory card password.i want to unlock it.my phone model is Nokia 2700Classic.plz help me.
Steps to Unlock a Password Protected Memory Card of Your Mobile PhoneThe steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
  7. When you finished the above steps, you will find the password of that file.
Feb 15, 2011 | Cell Phones
how to unlock memory card
I have seen such a case when one my friend forgot the password of his memory card of his mobile phone and he have some very important data in the memory card which he want to recover, he tried almost everything then he lost hope and then asked the mobile phone company to find the way to recover the data from the memory card. But you don?t worry if you are having the same problem?as now there is a much simple and easy way out. Requirement: You need a file explorer like FExplorer that u get from www.google.com Read more: http://www.mobiletipstricks.com/how-to-unlock-the-password-protected-memory-card-of-your-mobile-phone/#ixzz0QGFLtxQP Method 1: Insert card into your phone but don?t access it through phone. Run FExplorer and Open the path C:\system. You will find a file called mmcstore ,rename the file mmcstore.txt Copy that file(mmcstore.txt) to your pc and open that file in notepad. You will find your password in that file. Read more: http://www.mobiletipstricks.com/how-to-unlock-the-password-protected-memory-card-of-your-mobile-phone/#ixzz0QGFWvvU6
Sep 05, 2009 | Nokia 6300 Cellular Phone
unlock 1 GB micro sd memory card of Kingston Made
hi this is Aravind , i'm having 1 GB micro sd memory card for my mobile nokia 6233 ..... and it is password protected ... bit actually i have forgotton the password and now i'm using another phone ... in other phone the memory card is not openinng its asking for password .... i have tried also by connecting the data cable but in nokia pc suite its showing that there is no memory card ...., i had also tried thru card reader's but its not opening ./... is there any solution to unlock this card without losing the data in memory card ... plz help me out ........
i have microsd card 1gb card of kingston. it is locked & i want to unlock my memory card without losing my data. so pls send me tips for unlock the meemory card
i forgot my password...pls help me unlocked it without losing my files n data... i forgot the password of my micro sd memory card 1 gb , i don't bother about data, how to open , pl explain.
Jul 19, 2008 | Nokia N95 Cellular Phone
183 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
