Tip & How-To about Computers & Internet
Speed Up Shut down !! Speed Up Shut down !! October 18th, 2008 1> Go to Start. 2> Click on Run. 3> Start Regedit. 4> Navigate to HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control. 5> Click on the ?Control? Folder. 6> Select ?WaitToKillServiceTimeout? 7> Right click on it and select Modify. 8> Set it a value lower than 2000 (Mine is set to 200).
Computers & Internet Logo
I picked up this program called personal antivirus and I can't get rid of it.i looked in my programs and it's not even there.Any ideas?
go to start menu, then go to "run", then type regedit and hit enter.
Now you are in registry.
Find the HKEY LOCAL MACHINE and expand it, then find Software, and expand it. You should see your program here, right click and delete file.
Do the same with HKEY LOCAL USER
Also go to start menu, search , type program name. When found, right click and delete all files.
Oct 01, 2009 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
cd drive not detected
Lets do this.
1. Close all programs
2.Click on Start, Run, and type REGEDIT and press Enter.
3.click HKEY LOCAL MACHINE - SYSTEM - Current control set - control - class - select {4D36E965-E325-11CE-BFC1-08002BE10318} - on the right hand side you'll find upper filters and lower filters entries - right click and delete both(Upper and lower filters) - restart your computer and hope this works for you,
Awaiting response.
Thanks..
Sep 08, 2009 | Acer Aspireā„¢ T180 PC Desktop
my taskmanager has been disabled by virus
Method 1 Click Start, Run and type this command exactly as given below: (better - Copy and paste)
Method 2 Download and run this REG fix and double-click it.
Method 3
  • Click Start, Run and type Regedit.exe
  • Navigate to the following branch:
HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
  • In the right-pane, delete the value named DisableTaskMgr
  • Close Regedit.exe
Method 4: Using Group Policy Editor - for Windows XP Professional
  • Click Start, Run, type gpedit.msc and click OK.
  • Navigate to this branch:
User Configuration / Administrative Templates / System / Ctrl+Alt+Delete Options / Remove Task Manager
  • Double-click the Remove Task Manager option.
  • Set the policy to Not Configured.
Feb 12, 2009 | Computers & Internet
138 people viewed this tip
David Payne
David Payne
