Tip & How-To about Video Game Consoles & Games
How to make the battery life of a rechargeable electronic device last longer.
Have you noticed how the more you use a rechargeable appliance, the shorter it's battery life is? I don't know the exact reason, but what makes sense in my mind is that if you let the battery run out over, and over, and over, there is a little bit of the charge that you cannot recover and use, thus making the life of the battery shorter, thus giving you less time with the appliance. I have experienced this with my first Nintendo DS, which after letting the battery die over and over, would charge for hours on end and only last for a little bit more than half an hour. The way to stop this from happening is quite simple. I have a second generation Ipod, which i have had for about 3 years, and it still has almost full battery life. The trick is to keep the battery more than halfway charged all the time. The only, I repeat, the ONLY time you want the battery to run out is the first use. Yes, that is the opposite of what I just said, but it works. Trust me. I bought a new DS and used the same tactic, though i dont know if it was more than half a battery, and I have had it for almost 4 years, and the only thing wrong with it is the right trigger. I've dropped it several times on the trigger, and that is why sometimes it doesn't work. So, next time you buy a rechargeable appliance, keep this in mind.
Video Game Consoles & Games Logo
My extra battery will not take a charge. What should I do?
If you know that your charger is good buy a new battery. Batteries do have a service life.
One of the warning signs is that battery has a shorter usable time before requiring a recharge.
May 22, 2015 | Drills
my casio exilim battery shows low battery even after charging completely.
Rechargeable batteries, unfortunately, do not last forever. The older the battery and the more it's been used and recharged, the shorter the life. You will get to a point where the battery will only last 30 minutes or so, and will take only 20 minutes to charge (if you have a charge indicator for you battery).
My suggestion is to look online for a replacement battery. There are many places that sell generic batteries that work very well, so you don't need to spend the extra money to buy a real Casio battery. Just do a search for your battery model number.
Good luck.
May 09, 2011 | Casio EXILIM ZOOM EX-Z60 Digital Camera
My batteries are lasting shorter and shorter times. I had to change batteries after only 40 pics. Is it a camera problem or cheap batteries? I normally use the CRV3 batteries, but have been using AA's. Is this the reason why?
Digital cameras are famously demanding on batteries. You must use good alkaline batteries or better, a set of high capacity NiMH rechargeables. Zinc or "long life" batteries just aren't up to the task, and they can leak and cause corrosion.
NiMH batteries with a capacity of 2700mAH are available, and these will last longer, per charge, than name brand alkalines, as well as being rechargeable. You can buy these with a charger fairly cheaply now (though they obviously cost more than disposables). You will probably want two sets, one to be on charge while you use the other.
Jan 02, 2011 | Kodak EasyShare Z740 Digital Camera
Camera says replace batteries even when fresh ones are installed
Sir/Maam,
Have you tried using new batteries? How long have you been using the old batteries? As far as i know, the longer you use a rechargeable batteries, the shorter its life(compared to the first time you used it).
Try using new batteries, if the problem is still there, the camera my have the problem. But if the camera works fine, then your old battery is defective.
Keep me update, hope i helped you. Thanks.
Feb 27, 2010 | Canon PowerShot S3 IS Digital Camera
my phone will not charge
It sounds like the battery is a goner but I wouldn't swear to it without having another to test it. Over the course of the last month or so, did you notice that the battery life was shorter and shorter? It will look like it is charging but holds no charge whatsoever upon removal from the charging base. The best way to test this, of course, is to install a new battery. Finally, is this an older phone or a new one? Rechargeable batteries are good for about 2 years, less if you don't let it fully discharge and recharge although in the newer types it's not as much of a problem. Let me know what you find out.
Feb 11, 2009 | Philips SINGLE HANDSET USB VOIP PHONE
1,390 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
