Tip & How-To about Refrigerators
How to stop top freezer from ice ing up on (frost free) fridge HOT POINT
I recently had the problem of my freezer ice ing up on my " HOTPOINT" 18cu" fridge. i kept taking everything out and manualy de-frosting it. i got so frustrated doing this every 3-5 days so i did this : Behind the plastic cover at the back there is a coil. attached to this coil is a round silver part with wires attached to it. it is somekind of temperature sensor. this was the culprit.. here is wat i did to fix my problem.. : FIRST " UNPLUG FRIDGE" !! remove all contents, remove both BOTTOM AND TOP PLASTIC COVERS, if coil is all ice, thaw with hair dryer, if not iced up look for a SILVER , ROUND, sensor approxamately 3\4" high by 1" across. <----{ this sort of looks like a plastic bottle cap.. }CUT WIRES as close to this sensor as possible. REMOVE from coil tube.it will just pull off of coil. take care not to damage this coil or tube in the process.. with this sensor removed , just use yellow or orange wire nut and put these wires TOGETHER and attach wire nut and wrap electrical tape around wire nut and wire. put plastic covers back into place, put all contents back into freezer, plug fridge back in.. " D O N E ". its been 4months now and fridge and FREEZER work better then ever... this fix cost me $0.00 i can't get photo into here. sorry.. this process takes about 10 to 30 minutes to complete..
Refrigerators Logo
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Siemens KG39NA00GB fridge freezer auto-defrost problem.
When you defrosted manually, did you get a lerge amount of water down the back of the unit? If not. the drain is blocked. Also clean and clear the condenser
Apr 24, 2012 | Refrigerators
Frost free freezer icing up
It should still be covered under the warranty.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 02, 2009 | Amana ATB1832AR Top Freezer Refrigerator
My frige stays warm all the time it is a Hotpoint
evaporator coils are iced up on the freezer side. either take everything out of the fridge and unplug it and let it sit for a day to defrost, or remove the inside rear panel where there is frost and (with the fridge off) use warm water sprayed on the ice to defrost it (or use a hair dryer, but just until the ice is melted. do not overheat the metal). soak up the excess water (underneath the fridge, too), and turn it on empty. let it run empty for a day to get it cold, then put the stuff back in. if the stuff is in there when it's warm, the humidity will ice up the coils again.
Jul 23, 2009 | Hotpoint HSS25GFP Side by Side...
hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
180 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
