Tip & How-To about Computers & Internet
How to extend the life of your cannon printers and recycle ink as well
The main problem of canon printers nowadays is that it has lifespan when the waste counters of the printers become full you can no t print anymore.
To fix this problem all you need is intravenous fluid hose,phillips screw driver, drill,empty container and a lot of guts
first things first is open your canon printer using the screw driver after opening you'll find a hose where the printer cartridge sits this hose has a black stripe on it and goes directly to a catching pad which is commonly know as waste pads. pull out the hose from the waste pad and connect the intravenous fluid hose after you've done it secure it with a glue stick, glue gun or anything. Now drill a hole on the back side of the printer cover the hole must be of the same size of the intravenous fluid hose. assuminbg that you have already done this.insert the hose to the hole you've made and cover back your printer. now find a container for your waste ink. then you are done
to recycle the ink that you've collected on your catching basin just filter the ink out with a cloth and refill the waste ink as black. i've been doing these for a long time already and saved alot of ink for my black cartridge. hope this helps
Computers & Internet Logo
i cannot print from canon ip2770 printer...the orange light flashes five times
  1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
  2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
  3. Run GeneralTool.exe
  4. Select the connected USB port number from USB PORT
  5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Jul 06, 2011 | Office Equipment & Supplies
Canon Pixma Ip1700 will not print, because the Ink absorber is full.
Hi there
Please under-stand at some time you will need to clean out the waste inkpads that are inside your printer or it going to be a big mess of inks coming out.
Some times the IP tools will fix it Canon Pixma iP1200, iP1600, iP2200 Resetter
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 15, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
I have a Cannon iP1600 printer and when i want it to print, it tells me that the waste ink absorber is full. How can I fix it?
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
2. Unzip downloaded file by etc
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Jan 10, 2010 | Canon PIXMA iP1600 Printer
waste ink absorber?
Hi. As you have not mentioned the make and model of the printer, I am giving here the procedure to reset waste ink counter applicable to most printers. Hope it helps.
If you have a different printer model, then please tell me and I will research that for you. Thanks.
Jul 29, 2009 | Canon PIXMA iP1600 Printer
canon i550-turn on-orange/green 8x then long green
From the Canon website:
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Ink Absorber Replacement Options i550
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
For the Waste Tank Reset Code, and how to repair or replace the Waste Tank, see this website:
http://www.bioscomputers.ca/CanonWasteTankCodes.htm
Jul 16, 2009 | Canon BubbleJet i550 InkJet Printer
235 people viewed this tip
David Payne
David Payne
