Tip & How-To about Hotpoint Ultima WF860 Front Load Washer
List of codes for Hotpoint, Creda, Ariston, Indesit, Cannon
Appliance tagged Hotpoint, Creda, Ariston, Indesit, Cannon are all distributed by the Indesit appliances group.
All this brands share parts, they share the same error code list, and the service is provided by same centres.
I will publish a list of error codes for Hotpoint, Creda, Ariston, Indesit, Cannon.
Washing Machines and Washer Dryers
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
  • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
  • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
  • F13 - Check the water supply, inlet valve and hot and cold hose connections.
  • F14 - A fault with the water heating has occurred
  • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked
  • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more.
  • F17 - Door not closed properly. Close door firmly at 3 o'clock position
  • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing
  • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book service
  • F40 - Water below protection level during a heat step
  • F41 - Water level detect sequence incorrect
  • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language).
Fault codes for LCD EVO1 Washers
  • F01 - Short circuit motor triac
  • F02 - Motor jammed tacho detached
  • F03 - Wash thermistor open/short circuit
  • F04 - Pressure switch jammed on empty
  • F05 - Pressure switch jammed on full
  • F06 - Program selector error
  • F07 - Heater relay stuck
  • F08 - Heater relay cannot be activated
  • F09 - Incompatible eeprom
  • F10 - Pressure switch not sensing correctly
  • F11 - Pump cannot be activated
  • F12 - Communication error
  • F13 - Dryer fan or dryer thermisotor fault
  • F14 - Dryer element fault
  • F15 - Dryer element relay fault
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock
Fault codes for LCD EVO2 and V4 Washers
  • F01 - Motor traic short circuit
  • F02 - Motor jammed or tacho detached
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • F08 - Heater relay stuck
  • F09 - Setup error
  • F12 - No communication between cards
  • F13 - Drying thermistor open/short circuit
  • F14 - Drying element faulty
  • F17 - Interlock error
  • F18 - Communication error
  • H20 - Not filling. Check tap, hose and inlet valves
Fridges and Freezers
  • F1 - Freezer thermistor open circuit
  • F2 - Freezer thermistor short circuit
  • F3 - Fridge thermistor open circuit
  • F4 - Fridge thermistor short circuit
  • F7 - Evaporator thermistor open circuit
  • F8 - Evaporator thermistor short circuit
  • F9 - Temperature set switch open circuit
  • FA - No feedback from Baffle
  • FB - Fridge Baffle motor operating continuously
  • FE - Defrost time out
Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level.
  • F20 - Temperature under range
  • F21 - Temperature over range
LCD Dishwasher Models
  • A01 - Float switch
  • A02 - Open/Short circuit heater relay
  • A03 - Short circuit on thermistor or Time-out drain- Check filter for blockages then book a repairif the problem persists.
  • A04 - Unable to reach or sense temperature within 70 minutes
  • A05 - Pressure switch has not been reset
  • A07 - Open/Short circuit wash motor triac
  • A08 - Open/Short circuit auxiliary wash motor triac
  • A09 - Open/Short circuit with main wash traic
  • A10 - Open/Short circuit fill valve traic
  • A11 - Half load valve traic or alternating motor action
  • A12 - Open circuit heater rely
  • A13 - Open/Short circuit dispenser traic
  • A14 - Drain hose too low causing syphoning. Check drain hose.
  • H20 - Check tap and pressure of incoming water.
Hotpoint Tumble Dryers
  • F1 - The level of required dryness has not been reached within the time period. Check that the correct programme has been selected
  • F2 - Thermistor or sensing circuit failure
  • F3 - Heater plate over temperature. Check the filter and vent hose for a possible blockage
...Follows--->
Hotpoint Ultima WF860 Front Load Washer Logo
How to put belt on hotpoint dryer
Dryer Belt Replacement - YouTube
? 6:23
https://www.youtube.com/watch?v=dFB4vnmADh0
Jun 20, 2011 - Uploaded by Repairs101
How to do-it-yourself instructional on changing the drive belt on an electric ... She wanted to know about replacing the drive beltin her clothes dryer. ..... How to replace tumble dryer beltHotpoint, Indesit, Ariston, Creda, Proline ...
How to replace tumble dryer belt Hotpoint, Indesit, Ariston ...
? 9:36
https://www.youtube.com/watch?v=kNJGHyEPiJA
Jan 30, 2014 - Uploaded by how-2-repair.com
How to replace tumble dryer belt Hotpoint, Indesit, Ariston, Creda, .... to get right and the grooves correspond to the drive, so really obvious..
Dryer Drive Belt (part #WE12M29) - How To Replace ...
? 5:14
https://www.youtube.com/watch?v=ZXSJlWcZPiY
Oct 25, 2013 - Uploaded by AppliancePartsPros
Buy the new Dryer Drive Belt WE12M29 ... to replace the Dryer Drive Belt WE12M29 on GE, Hotpoint, RCA, Sears, and Kenmore dryers.
Jan 01, 2016 | Hotpoint Dryers
anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint tcym 750c tumble dryer serial number tcym750c6p. The wires attached to the timer control and start button have disconnected does anyone know how they go back on?
images for Hotpoint tcym 750c tumble dryer wiring
Hotpoint TCYM 750C Style - YouTube
? 3:07
https://www.youtube.com/watch?v=RjQMN6U4PdE
Oct 8, 2012 - Uploaded by Missing Sleep
Hotpoint TCYM 750C Style. Missing Sleep ... How to replacetumble dryer belt Hotpoint, Indesit, Ariston, Creda, Proline etc - Duration: 9:36. by ...
Hotpoint tcym 750c tumble dryer serial number tcym750c6p ...
www.fixya.com/.../t25992053-hotpoint_tcym_750c_tumble_dryer_seria...
48 mins ago - SOURCE: Reconnect wiring on a Hotpoint VTD00 tumble dryer. most electric dryers have a wiring schematic on the back or inside on the back ...
Dec 03, 2015 | Hotpoint Dryers
my front load dryer the knob to turn it on is cracked inside how do i get a replacement for it?
You can order one online from any number of appliance parts sites, such as ereplacementparts.com. Enter your brand and model number, then pick out the part you need from the displayed illustration.
If you live in a larger metropolitan area, then find a local appliance parts supplier in the yellow pages.
Apr 15, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
4,611 people viewed this tip
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
