Tip & How-To about Computers & Internet
Bluetooth Driver Installer
Often it happens that the device having Bluetooth doesn’t get detected by computer due to missing drivers and if you don’t have software cd which comes along with the device or gadget then it won’t be easy to get Bluetooth drivers. In such cases Bluetooth Driver Installer may come handy this utility will try to install generic Microsoft drivers for your Bluetooth hardware. Before making any changes to system do make sure to create system restore point.
Download Bluetooth Driver Installer.
Computers & Internet Logo
bluetooth peripheral device driver missing
You should install the driver software for your Bluetooth module built in. Check the CD or DVD(If came with your laptop) and install the driver from it. Then update it.
If you don't have any CDs or DVDs came with your laptop, go to the official website of the manufacturer of your laptop and download the drivers by yourself
Otherwise, you can visit the retail shop you bought your laptop and ask from them for the drivers.
Jun 12, 2017 | Cell Phones
how do i turn on my bluetooth on my emachines pc
Click the "Start" button, then choose "Control Panel," "Network and Internet" then finally "Setup a Bluetooth enabled device."
Power on the Bluetooth Hardware you want to connect to the computer. You must have some sort of hardware to connect to the computer, in order to enable the Bluetooth connection.
Click "Add" and the computer searches for any Bluetooth hardware in the area. Once it detects the hardware, select it and click "Next."
Type in the passkey for the Bluetooth hardware (found in the device's user manual) and click "Next."
Install any drivers now that came with the Bluetooth hardware. (Insert the driver installation CD that comes with the Bluetooth hardware, wait for the the installation wizard to load onto the screen, accept the license agreement, then click "Next" for the installation name and location and select "Install" to install the drivers.)
Choose "Locate and install driver software" if there are provided drivers. If not, click "Don't show this message again for this device" and click "OK."
hope this helps
Aug 12, 2012 | E-Machines eMachines W2686 PC Desktop
cd/dvd drive device driver missing when installing windows 7 ony my HP G72-B62US notebook
I'll recommend you to directly try Driver Detective and let the software have a free scan to automatically detect & update the missing drivers. This way things can be much easier & efficient. Also you don't have to risk install wrong drivers which might cause severe system issues.
best regards & good luck!
Jul 05, 2012 | HEWLETT-PACKARD HP G72-B62US Notebook
A month ago my window is vista and now I replace a new one "the window 7' then now I cannot find the memory card reader driver and the webcam together with the bluetooth device thats why im so stressed everytime I remember that problem would you please help me? Thank you
Some PC Laptops have devices that doesn't supports Windows 7 Operating System. Even if you search for the driver in the Internet, if the PC Laptop doesn't support Windows 7, you can never find a driver that device. Here try using these if these will help you fix the problem, but do not expect that this will be 100% that it will fix your problem. As I said earlier there are some PC Laptops that don't supports Windows 7, But theres no harm in trying. Heres the Solution.
  1. First, you must download this software. DOWNLOAD
  2. After downloading the software, Extract the file into a folder.
  3. After Extraction, Go to the folder and click on the Setup file.
  4. Once the software is installed, Run the program and Start the Scan, This will start the scanning of installed devices in your computer.
  5. Now after scanning, Browse for your missing drivers (MemCard Reader, Bluetooth, Webcam)
  6. Click the download button parallel to the device to download the driver.
  7. Now after downloading the driver, you will see a install button beside the download button, click it to install the driver.
  8. After installing the driver, I suggest you reboot you computer for the newly installed software to take effect.
  9. And your Done.
Now if the procedure above, worked for you.. then congrats, your PC is Windows 7 Compatible. But if the device is still missing, I suggest you change your Operating System to the OS that is supported by your Laptop.
Goodluck. Hope my solution will help you. Thanks for using Fixya! Have a great day!
Jul 09, 2011 | Acer Computers & Internet
how to activate Dell vostro bluetooth
1) Install the bluetooth driver provided for your system. It will ask you to activate bluetooth by pressing fn+f2 key (this won’t work).
2) You manually have to install the software for the driver.
Note: some of you may have already installed the drivers but just cannot start the connection. So there is a problem in the software and not the driver.
For installation of the software follow these steps.
3) Go to your driver installation directory (ex. C:\dell\drivers) then you find which driver you installed for your bluetooth.
4) Then you find your system you are running (a 32 bit or a 64 bit) it will written as win32 or win64.
5) Then you find the installation file. Then install the application and it will be all ready once again.
P.s. don’t forget to turn your Bluetooth adapter on after you install the software.
May 20, 2010 | Dell Vostro 1510 Laptop
200 people viewed this tip
David Payne
David Payne
