Tip & How-To about Computers & Internet
Windows 7 tips It?s a Drag.
It’s a Drag. Much play has been made of the Jump Lists feature in Windows 7, allowing applications like Windows Live Messenger to offer an easy task-based entry point. Jump lists replace the default right-click context menu in the new taskbar; another way to access them (particularly useful if you’re running Windows 7 on a one-button MacBook) is by left-clicking and dragging up in a kind of “swooshing” motion. This was designed for touch-enabled devices like the beautiful HP TouchSmart all-in-one PC, where the same gesture applies.
Computers & Internet Logo
Windows Live Messenger Error 0xc0150002
Did you try installing the Windows Live Messenger 2009 and if Yes please check if all the Instances of Windows Live Messenger 2008 has been uninstalled and if yes and uninstall the Windows Live Messenger 2011 and check what OS is he using Windows 7 32 bit or 64 Bit and download it from
http://www.microsoft.com/windows/windowslive/rediscoverconversation/
Let me know what happens after that.
Jun 22, 2012 | Microsoft Windows Live Messanger
i accidentally uninstalled msn messenger now i want to install msn messenger again
http://download.cnet.com/msn-messenger-wlm-polygamy/3000-2150_4-10559796.html
MSN Messenger (WLM) Polygamy 2009 allow you use multiple copies of msn messenger at the same time. Supports all versions of MSN Messenger including versions 7.x, 8.x, 9.x and 14.x ( Windows Live Messenger). It is easy to use, Double-click MSN_Polygamy.exe to run the program, and then click the Patch button, then your MSN Messenger can run more than one copy simultaneously. Version 14 added support WLM version 9.x,14.0.5027.0908.
http://download.cnet.com/msn-messenger-windows-98/3000-2150_4-10193172.html
http://download.cnet.com/windows-live-messenger/3000-2150_4-10450926.html
hope this helps you
Sep 19, 2011 | Computers & Internet
Looking for a tool that would allow me to connect MSN messenger and facebook. Is it even possible?
Sure. I know what you look for. The apps name is 'MSN Messenger Button'.For MSN / Windows Live Messenger users, this application lets them add an MSN Messenger Button to their Facebook profile page. It allows contacts to add users to their MSN Messenger contacts. It also lets users find out who among their Facebook friends are using MSN Messenger and allows them to be added as contacts. In addition, this application also lets users chat with MSN Messenger friends right on their Facebook profile.
Sep 20, 2010 | Facebook Apps
logitec web cam
You will be required to run an audio setup wizard through the messenger application in order for MSN or Windows Live Messenger to recognize sound using a microphone and produce sound through speakers, headphones, or headsets.
The information in this article will describe the correct procedure to setup audio and video within the MSN or Windows Live Messenger application to achieve proper audio functionality.
trnsp.gif Answer The information in this article applies to the following 3rd party software
MSN Messenger 6.x
MSN Messenger 7.x
Window Live Messenger 8.5
The information in this article applies the following platforms
Windows 98
Windows ME
Windows 2000
Windows XP
Windows Vista
Note: The information in this article is not product specific. For details regarding camera driver and operating system support please see article 3428
Step 1: Getting Started
Before we begin setting up the sound in MSN or Windows Live Messenger, ensure the following is complete:
  • Connect your camera and verify that it is working properly
  • If using headphones, verify that your device is connected and functioning
  • If using speakers, verify that they are functioning properly
  • If using a headset, verify that both the headphone and microphone are connected and working properly.
Step 2: Executing the audio and video setup procedure within the messenger application
This procedure will allow you to assign an audio input and audio output device, as well as assigning the video device of your choice to work with the messenger application. The following example uses Windows Live Messenger 8.5 however, the same procedure can be used for earlier versions of MSN Messenger 6.x and above. MSN Messenger users please skip directly to step 4 below.
Note to Windows Live Messenger users: There are multiple ways to execute the following steps depending on being signed in vs signed out of the messenger application, and which version of Windows Live Messenger is being used. To avoid confusion, please execute the following steps while signed out. We also recommend updating to the latest version of Windows Live Messenger.
1. Sign out of your account.
2. Launch the messenger application (make sure you are not signed in to your account).
3. Locate and click the "Help" drop down button towards the top right corner and select "Show the menu bar"
16480.gif 4. Now click the "Tools" option in the menu bar and select the “Audio and Video Setup” option.
5. Click “Next to begin the setup process.
6. In the “Speaker Setup” window, select the output device you would like to use with the messenger application. This step is specific to speakers or headphones. If your speakers or headphones are USB devices and connected to your computer, select the device by using the drop down menu provided. If your speakers or headphones are connected to your soundcard, the device listed will be the make or model of your soundcard device.
You can also set the desired volume level and click “Play Sound” for an audio sample. Click "Next" once you are comfortable with the your selected options.
7. In the “Microphone Setup” window, select your desired input device from the drop down menu provided.
3172_msnad04.jpg This selection will be specific to a microphone connected to your computer. If your Logitech video camera has a built-in microphone, this option will be presented as “Logitech Mic” with your camera model name in parentheses as shown above.
If you have an external USB microphone or headset device connected to your computer that hosts a microphone, select the devices name or model number in the drop down menu. If your external microphone or headset is connected to your soundcard, the device listed will be the make or model of your soundcard device. Once your device is selected, adjust the microphone volume level to your preference and click next.
Note: The microphone volume level may need to be tested in order to find a comfortable volume level. As a starting point, try setting the level midway and adjust when necessary by re-executing this procedure.
8. In the “Webcam Setup” window, select the video device you would like to use with messenger application. Once selected, you should see a display sample in the window provided. You can also click the “Options” button to make camera specific adjustments. Once completed, click the “Finish” button to apply your changes.
Once you have completed this process, the messenger application should now be configured to the correct audio input (microphone), audio output (speakers or headphones), and video device (webcam) to use when engaging in an audio and or video conversation.
Jan 24, 2008 | Logitech Webcam
133 people viewed this tip
David Payne
David Payne
