Tip & How-To about Dell 5100cn Laser Printer
Replace Transfer Roller
If the printer still says to replace transfer roller even after it's replaced, then remove transfer roller and manually turn the gears on the transfer roller a few times. It must get stuck or something. Then replace the transfer roller and it should work.
Dell 5100cn Laser Printer Logo
PRINTER SAYS TO SET TRANSFER ROLLER, NOT SURE HOW TO SET
Ensure transfer roller is properly installed.Turn printer off and check transfer roller contacts. Are contacts present and not damaged? If yes, Replace engine controller board.
Otherwise, If contact A (please see attachment) has slipped off frame, put it back on. If you cannot see it, remove HVPS cage and put it back in place. If B is damaged, replace registration assembly.
Dec 21, 2012 | Lexmark C500n Laser Printer
error 59.99 for HP laserjet 3550
Thank you for contacting Fixya with your printer inquiry.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=411173
HP Color LaserJet 3500, 3550, and 3700 Series Printers - 59.99.00 Error Displayed on the Control Panel Issue
When faced with a 59.99 error, we have found additional ways to solve the issue since the service manual was written.
Error: 59.99.00 Description: An error occurred in the secondary transfer engaging mechanism. Solution
Follow the troubleshooting steps below:
  1. Fuser seated improperly. Reseat the fuser.
    NOTE: You may hear grinding sounds from the right, rear of the printer associated with this specific failure also.
  2. Faulty secondary transfer engagement sensor. Replace the secondary transfer engagement sensor. (PS16, part of paper pickup/feed assembly)
  3. Faulty secondary transfer engaging solenoid. Replace the secondary transfer engaging solenoid. (SL4, part of paper pickup/feed assembly)
  4. Faulty feed motor. Replace the feed motor. (M1)
  5. Faulty DC controller PCB. Replace the DC controller PCB.
  6. If the 59.99 error only occurred after removing and reinstalling the paper pickup/feed assembly, what may have happened is that the secondary transfer engaging solenoid SL4 may have become dislocated. See figure below. Verify position of tab on top of solenoid.
    Figure (See Link)
    h30499.www3.hp.com/hpeb/attachments/hpeb/bsc-413/.../1/343540.em
    Parts associated with this fix:
    Pickup/Feed Assm - RM1-0765-070CN).(Includes solenoid & sensor)
    DC Controller PCB (RM1-0510-000) DC Controller, CLJ 3500/3550
    Primary Transfer Roller Engaging Motor (M-5) RK2-0139
    Drum Motor (M-3) RM1-0733Drum motor - Provides power to turn cartridge drums
    Delivery Motor (M-2) RK2-0138
    Feed Motor (M-1) - RK2-0137 Located on lower left front of main right side plate assembly
    Secondary transfer engagement sensor. (PS-10) (Part of Pickup/Feed Assembly)
    Secondary transfer engaging solenoid. (SL-4) RK2-0145-000CN
    Formatter Assembly Q1319-67903
    Parts sources:
    http://lbrty.com/Products/HP/parts_hp/pnC3500.html (Very Good Parts Vender Catalog) http://www.feedroller.com/Store/clj3500.php (Parts Vender) http://www.laserprinterservices.com/hp3500/hp3500.html (Parts Vender) HP Customer: To order HP computer parts and printer parts by phone please call 1-800-227-8164 , Monday-Friday, 7:00am to 7:00pm CST.
    Thank you for using FixYa. Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 16, 2011 | HP Color Laserjet 3550 Printer
Reset tranfer roller instructions needed
> Support & Drivers > Phaser 6300/6350 Support > Search Results Solution: Replace the Transfer Roller bttn_print.gifMake Printable bttn_email.gifE-mail this page elem_1_spacer.gif CAUTION: Do not touch the surface of the Transfer Roller as fingerprints can cause image quality problems.
  1. Push up the latch on the front of the printer to open Door A.
  2. Squeeze the orange tabs on both sides of the Transfer Roller together, and gently lift the roller out of the printer. Dispose of the old roller as normal office waste.
  3. Remove the new Transfer Roller from its packaging.
  4. Grasp the posts on each side of the roller and insert the posts into the u-shaped guides inside the printer.
  5. Push down on the base of the orange tabs until you hear a click to lock the roller into position.
  6. Close Door A.
Looks like Roller should be detected and message should go away after you replace it.
May 28, 2009 | Xerox Phaser 6350DX Laser Printer
HP LaserJet 1200 series
Hi vgde2004: Here are some things to check.
1. The printer is in manual feed mode.
Possible solution: Change the manual feed setting in "printer properties"
2. The door is open,the media is out,the toner cartridge is installed incorrectly,or the paper is jammed. Check paper path.
3.Fan error
Solution:
1. Check fan cables for looseness.
2. Replace fan assembly
Dec 15, 2008 | HP Color LaserJet 3500 Printer
In the Phaser 6250 Color Laser Printer Service Manual (which I had to have emailed to me from my toner supplier since it is not available to the general public) I went to Chapter 6 - Error Messages and Codes. I had to reboot the printer. Here is the procedure.
Entering by rebooting the printer:
1. Turn the printer power OFF
2. Hold down the Back and Information buttons simutaneously and turn the printer
back on.
3. Continue to hold the buttons until the following message is displayed on the front
panel: Service Diagnostics V#.##, Initializing ....., and then release the buttons.
4. The front panel displays the Service Diagnostics Menu.
On the display is a menu. Find Transfer Roller. Press enter on this menu where it says Toner Waste (Not Full). Back out of the menu.
All of a sudden the machine came to life. You may have to turn off the printer and turn it back on again.
Good Luck
Jun 10, 2008 | Xerox Phaser 6250 Laser Printer
2,846 people viewed this tip
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
