Tip for Ultimate Care II LSQ9549L Top Load Washer
Replacing a Lid Switch on Whirlpool Top Loaders
posted on Feb 07, 2008
jsrock516
jsrock516
Rank: Guru
Rating: 96%, 8151 votes
This advice is for just about all Kenmore and Whirlpool model TOP LOADING washing machines. This is an easy repair that anyone with a little know-how and determination can perform.
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Good Luck.
Comment by jsrock516, posted on May 24, 2008
Your secret is safe with me, John. Better not tell her about this website or she may find out. Glad I could be of assistance to you. :o)
Very Helpful
Was this helpful?
Yes
No
39 people thought this was helpful
Comments
- May 24, 2008
I didn't tell the mrs. about these instructions, I read them about three time's in the other room and then grabbed some tools.
I grunted and groaned very loudly several times and came back into the living room dangling the broken lid switch, with a big smile on my face.
I am really a HERO NOW, bet I get steak tonight!!!!!! OR SOMETHING!!!!!!!!!
THANK YOU and I hope you keep this old man's secret!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Later John
Featured Tip
nxt prv
Add a Comment
Insert Link
Can you Help with these Washing Machines problems?
Answer
Water will not shut off. Continues to fill tub even at end of cycle.
Answer
8 year old whirlpool ultimate care II washing machine is suddenly more rough on clothing,... (More)
Describe your problem:
Select a Category:
Insert Link
What is this?
Select
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(773) 507-7822
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
