Tip & How-To about HP Pavilion a1410n (ER890AA) PC Desktop
Time and date automated in notepad
Open notepad
set the first line to be (without the quotes and in uppercase) ".LOG"
press enter and save/close the file
every time you open the file, notepad will automatically insert the system date/time at the
end of the file and add a new line where you can begin typing
HP Pavilion a1410n (ER890AA) PC Desktop Logo
accidentally closed windows explorer process
Improve the FixYa experience for everyone by voting. I want you to let me know if the solution(s) suggested were of any value. Constructive criticism is welcomed.
I'm Ben and -- hopefully -- I can provide some meaningful assistance.
Please follow these steps:
  1. Reboot your computer in the Safe mode with command prompt.
  2. Once Windows loaded, command prompt (black window) opens. Type notepad and press Enter.
  3. A notepad window opens. Type the following text into notepad:
  4. [Version]
  5. Signature="$Chicago$"
  6. Provider=Myantispyware.com
  7. [DefaultInstall]
  8. AddReg=regsec
  9. [regsec]
  10. HKCU, Software\Microsoft\Windows\CurrentVersion\Policies\System,DisableRegistryTools,0x00000020,0
  11. HKLM, Software\Microsoft\Windows NT\CurrentVersion\Winlogon,Shell,0x00000020,"Explorer.exe"
  12. Save this as fix.inf to your Desktop (remember to select Save as file type: All files in Notepad). Close Notepad.
  13. In the command prompt type Explorer.exe and Press Enter. Windows Explorer opens. Locate the fix.inf, click right button and select Install. Close Windows Explorer.
  14. In the command prompt type shutdown -r and press Enter. Your computer will be rebooted.
Jun 08, 2012 | Dell Computers & Internet
I got a code purple trying to restore my computer to its factory settings and now when my computer tries to boot up normally I can't log in using my old password or username and the only way I hav
With the code purple error on the screen, press the shift+f10 to open the cmd prompt.
Whe the cmd prompt opens, type the following command without the quotes "notepad C:\hp\bin\checkdmi\checkdmi.cmd", then after the REM lines add the following code without the quotes "goto cleanup". Save the file and exit notepad and restart your computer by typing the following command without the quotes, "shutdown -r -t 0".
This will cause the checkdmi function in an HP computer to bypass the tattoo check.
Hope this helps
Apr 04, 2012 | HEWLETT-PACKARD Computers & Internet
my new pc turns on but i cannot get the icons to show up
Hi lwoodward...
Try this solution, you may want to print to paper for a hard copy
Please rate me
reboot your computer in the Safe mode with command prompt.
[Version]
[DefaultInstall]
AddReg=regsec
[regsec]
In the command prompt type shutdown -r and press Enter. Your computer will be rebooted and your icons should reappear.
Aug 29, 2011 | Computers & Internet
configuration error code purple
1. Load the system recovery disk into CD-ROM
2. Press F10 repeatedly at boot screen to load the Recovery Menu
3. Press R for the recover console
4. Select "Advanced Options"
5. Press Alt + D to bring up the command prompt
6. type "cd h:\" to enter the root directory
7. type "dir /w" to view the directory in wide view
8. open the master.log file (or something along those lines), this should bring up a prompt asking you what program to open it with, you should only be able to select notepad.
9. open the file with notepad and when it appears select the File>Open
10. in the file name box type in "C:\hp\bin\configcheck\run.py"
11. once the file opens clear the contents and select save as then save the file as run.p_
12. close the notepad program
13. delete the original file by typing "del C:\hp\bin\configcheck\run.py"
14. reboot system
After a reboot the windows screen might flash a few times and take a little longer to load, be patient and you should be able to continue with the windows set-up without that damned code purple error message.
Oct 02, 2008 | Computers & Internet
1,661 people viewed this tip
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
