Tip & How-To about HP Pavilion a1410n (ER890AA) PC Desktop
MAKE THE DRIVES IN MY COMPUTER INVISIBLE!
You can make the drive list on anyone's (or maybe your) computer invisible.
Just Open Registry editor my going to Start->Run and typing
regedit command. Then locate following Key
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
Now create a new DWORD value and rename it to NoDrive . Modify its value and set it t0 3FFFFFFin hexadecimal Format.Close the registry editor to and you are DONE!
To re-enable it just delete this DWORD value
HP Pavilion a1410n (ER890AA) PC Desktop Logo
uimain exe
If you have sufficient computer expertise to deal with superior PC problems, you may consider repairing registry problems simply through built- in Registry Editor. Before editing the Windows registry, you need to make a backup for the registry files:
  1. Click Start, and then select Run, and type REGEDIT on the pop- up. Click OK.
  2. In the Registry Editor, select the registry key you need to back up.
  3. From the Registry menu, select Export Registry File option.
  4. From the Save In list, click the folder where you want to save the backup.
  5. In the File Name box, type a name for your backup file, such as "Options" or "Backup."
  6. In the Export Range box, be sure to select "Selected branch" option.
  7. Click Save. The file is saved with a .reg extension.
Once finishing backing up the registry files, you are allowed to edit the registry manually:
  1. Click Start, and then go to Run.
  2. Type "regedit" onto the dialog box, and then press Enterto enable Registry Editor.
  3. Find out HKEY_LOCAL_MACHINE folder and double click to open it. Then click "Software" folder, go to "Microsoft" folder, select "Windows" folder, click"Currentversion" Folder.
  4. Click "Run" folder ==> Click on the UIMain.exe file.
  5. Click Delete UIMain.exe key to remove the file.
Jul 16, 2013 | Computers & Internet
Error
U can clean ur all registry errors from reginout
Jul 26, 2010 | Dell Dimension 2400 PC Desktop
Drive Failure.... AGAIN
maybe its not the drive maybe its the software just try this one:
if you are using windows XP
- click start
- click run, in the run type in regedit
you will see a registry editor window
in the registry editor window
- click the + sign at the hkey_local_machine
- click the + sign of system
- click the + sign of currentcontrolset
- click the + sign of control
- click the + sign of class
there will be bunch of random letters and number under that control
try to find this one
{4D36E965-E325-11CE-BFC1-08002BE10318}
if you click this check if you will be able to see DVD rom at the right side of the registry editor window
you must delete the upper and lower filters
after that restart the computer and try to put in dvds
for vista or win7
- click start and type in the start search regedit
after this just do the same thing with the win xp instructions
try also to update the DVD codec. you can also try to download the most updated windows media player, power DVD or any software/program that have dvd codecs or that acts like a player for DVD
i hope this works.
Pls rate my resolution thanks!!
Mar 04, 2010 | Tascam CD-RW2000 Burner
I am trying restore windows vista on my ACER Aspire 5100 but a message keep coming up saying that Windows cannot open the required file D:SourcesInstall.wim. It also says the file does not exist and to make sure all files required for installation are required and I get the error code 0x80070002
This error is due to....
  • The default security provider in Windows XP, or
  • the System drive letter
  • To solve dis issue.. try one of the methods
    1)Reset Windows XP Default Security Provider
    1. Open Start menu, select Run, type regedit and then press Enter.
    2. In the Registry Editor window, locate and delete the following registry keys:
      HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptograp hy\Providers
      HKEY_USERS\S-1-5-20\Software\Microsoft\Cryptograp hy\Providers
    3. Exit the Registry Editor and restart your PC
    2)Reset The System Drive Letter
    1. Start your computer in Safe Mode-turn on the PC, and press F8 during startup. Next, when the Windows Advanced Options menu is displayed, scroll down and select Safe Mode.
    2. Open Start menu, select Run, type regedit and then press Enter.
    3. In the Registry Editor window, locate the following registry keys:
      HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
    4. Edit this key to change the value of the system drive.
    5. Exit the Registry Editor and then restart your PC
    Mar 20, 2009 | Computers & Internet
    1,444 people viewed this tip
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
