Tip & How-To about Computers & Internet
How to manually backup files on a corrupt Windows Vista using a Vista Setup DVD
The above, becomes very necessary for a lot of people who find themselves only having in their possession, their Vista Setup DVD in the case of a corrupt Windows Vista that will not boot at all even in safe mode. In these cases, one may want to perform a reformat and a fresh Windows Installation (especially in the case of virus attack) but would not want to lose his/her personal files. Now here's what to do:
First you will need another disk drive apart from the hard drive with the corrupt Vista Installation. It could be another hard drive partition on the same PC, an external hard drive, or a usb flash disk drive with enough space to copy the necessary files. In the case of an external drive, I recommend that you connect it to the PC before you turn it on.
Now turn on the PC, quickly insert the Vista Setup DVD, and boot from the CD/DVD drive. If your PC is not already set to boot from CD/DVD, you may have to go to BIOS setup to set the boot order to boot from the CD/DVD drive. The BIOS setup can be entered by quickly pressing the appropriate key which is normally shown on the screen when you turn on you PC. It's normally 'F2', 'Del', 'Esc' or another key depending on the system model. Most PC models also provide a key that can be quickly used to select the media to boot from when the PC starts.
After the Vista Setup DVD has Loaded, select the language and keyboard layout and proceed to the next stage. Click on 'Repair my computer' and wait for the resulting window. Now select your Windows and click 'load drivers'. You will be presented with an explorer window where you can browse 'My Computer'. Now in this mode, you will see and copy only folders not files but it does not mean that your files are not there. Since you can only copy folders, you may want to copy you 'Desktop' folder, and you 'Documents' folder and any other folder that you created that contains files that you don't want to lose. If you are wondering how to get to your Desktop and Documents folders, here's how: (Double click on the hard disk with the corrupt Windows Installation. Double click 'Users' and then double click on the desired user name. You will now see all the folders associated with the user name you selected including the Desktop and Documents folders). Right-click and copy the folders one after the other to you desired destination disk drive. Note that no copy progress is shown so you would have to look at your hard disk activity led to keep track of the progress (the hard disk led will be very busy blinking when copying and stop blinking when done). In the case of an external hard disk drive or a usb flash disk drive, you can use the activity led on them to keep track of the copying (they also stop blinking when copying is done). That's all. You have successfully backed up your files manually.
I recommend that, after your fresh installation, obtain a good Anti-virus software, update it and use it to scan your backed up folders before you access them. Hope this is helpful and I wish you all the best.
Computers & Internet Logo
My dvd player skips a lot or doesn't play movies at all. Help!
Most probably the lens has either become dirty in which case clean the lens using a DVD lens cleaner CD. Else the lens has become weak & needs to be replaced.
Nov 12, 2010 | TruTech LMD-5702RT Portable DVD Player
i have recently purchsed a toshiba a500 03p with vista home premium, how do i roll back to xp? I have xp rollback discs
In order to switch from Vista to XP, you will need to basically erase Vista and install XP.
I'm not exactly sure what you mean when you say you have XP rollback discs but, you will need an actual Windows XP installation disc and product key.
First make sure the BIOS in your pc is configured so that the first boot device is your cd /dvd drive.
Insert the XP cd in the cd /dvd drive and reboot the pc. Your pc should then boot from the cd and enter the text based portion of the XP setup program.
Press the F8 key to accept the licensing agreement and then wait for the setup program to load the files it will need to continue the installation of XP.
Once the necessary files are loaded the setup program will check for an existing installation of Windows and will identify the partition where Vista is installed and ask where you want to install XP.
This is where you want to pay close attention to the information provided on the screen. What you want to do is to delete the partition where Vista is installed and then create a new partition. This will remove Vista from your pc.
After the new partition has been created, you can then install XP onto it. The setup program will copy the files needed for XP to operate and will reboot your pc so it can enter the graphical portion of the setup program.
The graphical portion of the setup program is where you'll enter the product key and then the installation will continue installing the necessary files until it get finished.
Once completed, Vista will be gone and XP will be your operating system.
Sep 10, 2009 | Toshiba Computers & Internet
I Wanted To Make a BOOT CD For Windows XP But The Problem is That I Have Windows Vista and i Dont Know What To Do So What Can i Do
How to make a bootable Windows Vista ISO DVD media
  1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
  2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
  3. Exit from the Install Windows screen.
  4. Download CDimage 2.52.
  5. Extract CDimage from CDimage.zip to the C:\ root directory.
  6. Open a command prompt shell, and run the following command: cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
    Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
  7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Visit here for illustrative guide on using CDImage GUI version to make the bootable DVD ISO.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK).
  1. Complete step 1 – 3 as above.
  2. In the command prompt window, run the following command: oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
    A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
  3. Burn the ISO image file by using last step above.
Visit the guide to create Vista bootable DVD using vLite.
Note: For 64-bit Windows Vista, download etfsboot.com and put it into “\Vista\boot” folder. Or users using WAIK (WinPE), the etfsboot.com can be found at %Programfiles%\Windows AIK\Tools\PETools\amd64\boot\ folder. So simply replace -bC:\Vista\boot\etfsboot.com with -bC:\Program Files\Windows AIK\Tools\PETools\amd64\boot\etfsboot.com when making 64-bit Vista DVD image.
Aug 02, 2009 | Computers & Internet
windows vista
How To Make Vista Bootable DVD with WIM Downloaded Files If you have purchased Windows Vista online and taken the delivery of the latest operating system via web download from Windows Marketplace, you would ends up with a few downloads with .wim and .exe file extensions. Rather than paying additional shipping and handling charges, you can burn or create a bootable ISO DVD image from downloaded Vista files with the following trick, where the .iso image can subsequently write to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD that available in retail channel, and can be used to clean install.
1. Complete step 1 - 3 as above.
Mar 24, 2008 | Computers & Internet
vista compatability
y dont you try the other way round you become the host and update the setup to compatible with vista drivers then try and use the things!!!see if it works for you otherwise i will try and suggest another solution
Jan 31, 2008 | MSI : MP54G Wiress 802.11g Mini PCI Card...
173 people viewed this tip
David Payne
David Payne
