Tip & How-To about Cell Phones
LG RUMOR lock code
If your phone is locked and you dont know the lock code, enter the last four digits of your wireless number. my daughter locked her's by pressing and holding the #key. she freaked because she didnt know the lock code. i entered the last four and unlocked phone.
Cell Phones Logo
I have forgotten my unlock code to lg revere
This is copied directly from the manual - check out #5 at the bottom.
Hope it helps!
7.7 Security
The Security menu allows you to
secure the phone electronically.
1. Open the flip and press
[MENU]
2. Press Settings & Tools.
3. Press Phone Settings.
4. Press Security.
5. Enter the four-digit lock code.
The lock code is the last 4 digits
of your mobile phone number if
it is set. The lock code is the last
4 digits of your MEID if your
mobile phone number is not set.
Aug 02, 2012 | LG Revere MobiPhone - Black Verizon...
forgot lock code for lg vx3100
hi..
To lock the phone:
  1. Press the left soft key for Menu.
  2. Select Settings then press OK.
  3. Select Security then press OK.
  4. When prompted, enter the 4-digit lock code (the default code is the last four digits of the cell phone number).
  5. Select Lock Mode then press OK.
  6. Choose your preferred option then press OK:
    • Never
    • On Power Up
    • Always
To unlock the phone:
  1. Press the right soft key for Unlock.
  2. When prompted, enter the 4-digit lock code (the default code is the last four digits of the cell phone number)
thanks for rating
Jun 02, 2011 | LG VX3100
I have a 13 year old daughter, andhave taken her phone away from her. She locked the phone, and I need to see what is on it. How can I unlock the phone? It is a LG VX8300. Thanks
Sometimes, the last four digits of the phone number will not work as the unlock code, especially if your daughter has changed the code. Even if the phone is locked, dial *228, then press 1 when prompted by the automated system. When it tells you: "Your phone has been programmed successfully", press "Done" or "OK". Once the phone has powered off, then back on, (it will do this automatically) the lock code for the phone will be changed to the last four digits of the phone number. For example, if the phone number is (315) 123-0101, your lock code, after following the above instructions, will now be "0101". Also, you do NOT need to know the lock code that your daughter had for this to work. After the phone has powered back on automatically, you will be able to use the phone normally. *228 does not delete text messages, contacts, etc, but it WILL give you access to a phone which has been locked, without requiring you to know the code that she has set.
Jun 24, 2009 | LG VX8300 Cellular Phone
i dont remember the phone lock code of motorola v3i
Your phone’s four-digit lock/unlock code is originally set to 1234.
The six-digit security code is originally set to 000000.
If you forget your unlock code: At the Enter Unlock Code prompt, try entering 1234 or the
last four digits of your phone number. If that doesn’t work, press and enter your
six-digit security code instead.
Jun 24, 2009 | Motorola Mobility RAZR V3i Cellular Phone
How to unlock LG VX4400
Many people never program a password code to "Unlock" this phone, but can lock themselves out by pressing the # key for more than three seconds. I know, it happened to me when I was out of town and needed the phone to work! Anyway, press the button to the right of the large round button at the top of the keypad, you will get a prompt to enter the four digit "Unlock" code. The default from Verizon, and most likely the factory default from LG, is the last four digits of your cell number. Did this work for you too?
Mr Dennis
Nov 27, 2007 | LG VX4400
195 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
