Tip & How-To about Computers & Internet
How to change the battery in Dell
Hi friend,
A coin-cell battery maintains computer configuration, date, and time information. The battery can last several years.
If you have to repeatedly reset time and date information after turning on the computer, replace the battery. You can read anything about your dell dimension 4600 PC like....how to change the battery click on LINK
With Regards
Avnish Kumar
Computers & Internet Logo
Alert! system battery voltage is low
Hello there and welcome to fixya
This is a very common issue with these desktop units the cmos battery will only last from 2 t0 5 years depending on how it is used.
This battery sits on the motherboard so you will want to first unplug the computer then remove the outer cover to expose the internal parts then look for a coin sized silver battery that looks like a watch battery then replace the battery with a new one
radio shack has these then power up the computer and you will have to reset the time and date ok you will get a error about this. here is what the battery looks like
Aug 16, 2011 | Dell Dimension C521 PC Desktop
What type of CMOS battery does a Dell Dinmension 4600 use?
Hi friend,
With Regards
Avnish Kumar
Jan 09, 2010 | Dell Dimension 4600 PC Desktop
everytime I turn the camera on the time and date
There are two batteries in the camera. One is the big one you charge and the other is a little coin type battery. This coin battery maintains your settings and when it goes your camera forgets things. Same setup on computers and a lot of other electronics. In your camera the battery is a CR1220 worth about $1-$2. It should last about 3-5 years but you never know.
The battery is in a little holder on the left hand side of the camera. Its under the same cover as the usb connector and power plug in. You should be able to pop out the battery holder fairly easily. This is one of those things that if you take the camera to a battery store they will probably do it for you if they aren't busy. If you look at page 137 of your manual you will find the instructions for doing it yourself.
Sep 12, 2009 | Canon PowerShot A520 Digital Camera
how to know dell 370 precision battery
If the battery is changed, that will mean that the BIOS was set back to january 1 1980.
Go into BIOS, set the clock to the correct time.
For DELL 370 precision , here is the BIOS instruction:
http://support.dell.com/support/edocs/systems/ws370/
Replacing the Battery caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions located in the Product Information Guide. notice.gif NOTICE: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface on the computer.
The battery may need replacing if you have repeatedly reset the time and date information after turning on the computer or if one of the following messages appear:
Time-of-day not set - please run SETUP program
or
Invalid configuration information -
or
Strike the F1 key to continue,
F2 to run the setup utility
To determine whether you need to replace the battery, reenter the time and date in system setup and exit the program to save the information. Turn off your computer and disconnect it from the electrical outlet for a few hours; then reconnect the computer, turn it on, and enter system setup. If the date and time are not correct in system setup, replace the battery.
You can operate your computer without a battery; however, without a battery, the configuration information is erased if the computer is turned off or unplugged from the electrical outlet. In this case, you must enter system setup and reset the configuration options.
Jul 03, 2009 | Dell Precision 360 PC Desktop
Every time I bot up my pc the dte and time is
hi,
Coin-shaped batteries on most motherboards should be CR2032. Make sure it is properly installed and + is up. IF you have a multimeter or you have a friend who has a multimeter, remove the battery and check the voltage. It should read 3.0 volts when fully charged. If it reads 1.8 volts or higher is probably OK. Be very careful installing and removing coin-shaped batteries. Most of the battery holders i have seen for these batteries are quite fragile and easily broken. I ease these batteries into the holder with the aid of "tweaker" (small screw driver).
here is a video, you can see how to remove the battery or bypass bios password.
Apr 23, 2009 | Evesham Axis PC Desktop
159 people viewed this tip
David Payne
David Payne
