Tip & How-To about Computers & Internet
Migrating XP to Windows 7 (Using your Network)
If you are thinking of buying a new PC and trying to replace an old XP system to a new Windows 7, you might want to transfer your old favorite files to your new computer. Either transferring through a Easy Transfer cable, Network, or via USB
This procedures assumes that your old XP is still working and connected to your home or office network. and your new Win 7 is also connected as well to your networkBoth of your system and computer must be connected to the same network, either in the office or home, because it is easier to transfer files in this way, effectively and efficiently, this is practical than using USB flash drive or any external disk, though the process is similar.
Ensure that you have the Win7 InstallationDVD, or the Easy Transfer Software fromMicrosoft website, ready to be installed on your XP system. but be aware this is for 64 bit version system only, please visit Microsoft website search and download Windows easy Transfer and select "x86" in the file name for 32 bit or 64 bit, install this the same way you've done with ordinary software. In your Win 7 however, this software is automatically installed so do not bother yourself.
In this instance you will be asked if whether you want to transfer your whole data from all user accounts or to just specific user only, in this process you can also select specific files to transfer, but in order to transfer all accounts, both of your XP and WIN 7 must be logged as an Administrator.
So this procedure is Migrating through NETWORK, the other two procedure is Easy Cable Transfer and USB, external Hard disk.
1- Prepare both systems and ensure both are connected to the network and working, Start the XP computer and log in as an Admin
2- IN XP , Open up the and start the Windows Easy Transfer DVD, and look or browse for SupportMigwiz. if you have downloaded this simply select Start> All Program> Windows Easy Transfer for Win 7, it will load automatically. Simply read the screen for additional info and click Next
3- A new screen pops out and please select a Network as an option to transfer
4- Click This is my OLD COMPUTER, Still in XP Windows Easy Transfer will then generate a password for the transferring process, because in order to transfer files through the network you will be required to enter a password (record the KEY)
After you enter the key, at this time Windows Easy Transfer makes the connection and scans the Windows XP system's contents and components. Once this is over, you can practically choose which data you want to transfer, or you want to import, just like customizing the items you wish to transfer. After you have decided which is which, click Transfer, then a progress bar will appears the process occurs.
The final screen will then show up indicating the process is complete. Confirm to see if the file you have chosen was actually transferred, then close all window, including the Easy Transfer Windows.
Restart your computer, please. Congratulations!
Computers & Internet Logo
Have 2 pc's , need to tranfer old to new (files)
Only suggestion I have is back-up all important files and then reload to new computer.
Oct 28, 2012 | Dell Dimension 1100 PC Desktop
I use MS Money 2001. I bought a new PC and is changing from MS Windows XP Pro to Windows 7 Pro. I would like my ms money 2001 to continue working on new PC but I can't find the original disc to copy on new PC. Could I install ms money 2003 on old PC convert files to 2003. Copy 2003 on new PC and transfer files from old PC to new PC. Please help I am desperate Piet Mulder
Hi pjhmulder
Assuming MS Money 2001 and 2003 are compatible with W 7 , you could install MS Money 2003 on the new computer and copy the files from MS Money 2001 on the old computer to MS Money 2003 on the new computer . Make sure you don't erase the MS Money 2001 files before transfer has successfully been executed .
Best regards ,
fanaudi .
Aug 12, 2011 | Microsoft Computers & Internet
can micro cookbook 5.0 be adapted to run in Win 7?
Use the compatibility mode for the program. This will allow you to run it as if you had an older version of Windows. If it ran under Windows XP, this should work.
Right click on the icon and select Troubleshoot compatibility. The compatibility wizard will start and make a determination for your system.
Oct 27, 2010 | IMSI Micro Cookbook 5.0 Full Version for...
I just purchased a new laptop that has windows 7. How do I transfer my accounts and files from my old one that uses windows xp?
From the windows 7 computer, Start, Accessories,System Tools, Windows Easy Transfer. Follow the onscreen instruction. Note both system must be on the same network.
Aug 08, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I'm trying to sync my files from my old computer
no you can what you have to use is files and setting transfer wizard in windows xp you can start the Files and Settings Transfer Wizard by clicking Start on the computer running Windows XP, pointing to All Programs, Accessories, System Tools, and then clickingFiles and Settings Transfer Wizard. (If both computers are running XP, you can start with either one.)
just select "i want create wizard disk in following drive " and select you external disk drive tha will do the trick...
Apr 11, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
188 people viewed this tip
David Payne
David Payne
