Tip & How-To about Computers & Internet
How to get Aero on a Computer without Vista, or on an unsupported video card.
We all like Vista's Aero, even after 7 came out. But for most of us, we just don't want to stop using XP. Or we upgraded, and our computer doesn't support it. So, i am here to recommend a few programs that will give you an Aero Effect.
The first - Window FX - This will give you all the Aero Fade in and Out, and other effects that come with vista. Some versions support Transparency The download is here: http://www.stardock.com/products/windowfx/
The second - TrueTransparency - http://www.crystalxp.net/galerie/en.id.5139-truetransparency-lefreut-explorer-tools.htm This will give you Aero effects, and allows you to have different skins for it.
Others: Visual Tooltip which gives you a Tooltip when you put your mouse on the task bar, which comes with Window FX. http://www.chrisnsoft.com/visual-tooltip/
AeroShake - AeroShake is a Windows 7 Emulator. It allows you to shake a window, to hide all the others. This comes with TrueTransparency, so if you plan on using TrueTransparency, you don't need to install it. http://aero-shake.en.softonic.com/
AeroSnap - AeroSnap is also a Windows 7 Emulator. It allows you to drag a window to the top, or sides of the screen, and it will either maximize, or pull to either side of the window. http://www.mydigitallife.info/2008/11/29/aerosnap-free-download-to-enable-windows-7-aero-snap-features-in-xp-and-vista/
All together, these should satisfy, for now, our cravings for Aero, at least until our next computer...
Computers & Internet Logo
display stopped working than recovered
first check for a virus or malware
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
Aug 15, 2012 | Computers & Internet
Problem on the device driver/ motherboard
Boot under XP, go to Dell's website and download the XP driver for your laptop noting where it is saved. Don't install it, copy it to a thumb drive or a CD. Reboot into Windows 7 and then install the XP driver. You'll get a message that it isn't the correct one but choose install anyway. That chip doesn't fully support AERO in Win 7 but will do most everything you will need. If you want to disable the pointing stick on the keyboard, download the XP Dell trackpad software. That lets you go in and deactivate the pointing stick. I find it annoying.
Jan 07, 2012 | Dell Latitude D630 Notebook
my windows does not hav aero pick
If you are using Windows XP this option is not available in this operating system.
This feature was introduced in operating systems which were released after Windows Vista. So it is available in Windows Vista, Windows 7.
If you are using these operating systems then it is definitely has. Else either you have to upgrade your O/S to Vista / 7.
This feature is not activated by default. It depends on the hardware profile of your computer. If your desktop/laptop has less resolution graphics card then, this feature is disabled and there is no option to enable it as your h/w is not supporting this.
Hope this clarifies..
Sep 21, 2011 | Computers & Internet
i cant use my driver installer for ati radeon 9200 with windows 7
According to the AMD/ATI website, that video card chipset only supports Windows 98/98SE, ME, Win 2000 and XP. There's no mention of Windows Vista. Given that this isn't a relatively recent AMD/ATI release, it may or may not be supported under Windows 7 properly. It's almost a sure bet it won't do AERO properly - especially if it only has 64 MB of onboard video memory.
If you've got it installed in a computer with XP loaded, you can download the Vista Upgrade Advisor from Microsoft. It will tell you if you're going to have any problems with Vista. Windows 7 has a very similar driver model - and Vista drivers can be made to work with Windows 7.
Good Luck,
Jul 30, 2011 | Computers & Internet
how i can get window vista look in windows xp
http://rapidshare.com/files/52953075/Best_Vista_Theme_For_XP.rar
Click the link above, then click the free user button. Follow the onscreen prompts to download and install the program and it will install the Vista mods to your XP system.
Hope this helps FixYa,
Chris
Jun 06, 2009 | Microsoft Windows Vista Ultimate Edition
297 people viewed this tip
David Payne
David Payne
