Tip & How-To about Computers & Internet
If under various circumstances you had to install a second Windows OS on the same system, you should have already met the dual boot option. It will pop up before booting the system permitting the user to select which OS will boot.
Boot.ini, the house of the dual boot option Boot.ini is a system file found in the system root. Because it has a major importance for the booting process.so we have to edit this boot.ini file to remove multiboot popups.
How to edit Boot.ini
1.Go to Start Click on Run
2.Type msconfig.
Once the system configuration window pops up, you will notice that Boot.ini has its own tab. Select that tab and where you see "timeout," set it to a lower or higher value. Remove/Add Operating Systems in the dual boot menuThis is the main issue.
Step 1:Right click on My Computer icon and select Properties.
Step 2:From the properties window go to Advanced > Startup and Recovery > Settings.
Here, you can both edit the timeout value and modify the Boot.ini file by clicking Edit. If you remove the second operating system from Boot.ini, the dual boot option won't appear before booting.
For more details information visit How to Remove Multiboot Option in Windows XP
