Tip & How-To about Computers & Internet
How to Speed Up Your Computer Right Now
Take control of your computer. If you're running Windows XP, learn the easiest way to speed it up.
The process below is a bit long and technical. The quick speed method using software is here on http://digitalpowering.blogspot.com/2010/04/how-to-fix-registry-errors-and-optimize.html
Also access the MICROS FT PAC OF SOFTWARE HERE for fast speedong up computer
  1. Step 1
  2. Switch to Classic Mode:
    a. Right-click the desktop
    b. Select "Properties"
    c. Find where it says "Theme:" Underneath this, click the drop-down arrow, and select "Windows Classic"
    d. Click "OK"
    Reason: Takes less CPU power and RAM
  3. Step 2Disable Visual Effects:
    a. Click "Start"
    b. Click "Control Panel"
    c. Double-click the "System" icon
    d. Click the "Advanced" tab
    e. Under "Performance," click "Settings"
    f. Click the "Adjust for best performance" option
    g. Click "OK"
    h. Click "OK"
  4. Step 3Defragment the Hard Drive:
    a. Double-click "My Computer"
    b. Find the "C" drive, and right click on it
    c. Select "Properties"
    d. Click the "Tools" tab
    e. Click the "Defragment Now" button
    f. At the top, the "C" drive should be highlighted
    g. Click the "Defragment" button
    Reason: Increases speed at which files are accessed
  5. Step 4If you have one hard drive installed, perform this step. If you have two hard drives installed, skip this step and go to Step 5.
    Make Sure Virtual Memory is Set to "System managed size:"
    a. Click "Start"
    f. Click the "Advanced" tab
    g. Under "Virtual Memory," click "Change"
    h. Make sure the "System managed size" option is selected
    i. Click "Set"
    j. Click "OK"
    k. Click "OK"
    l. Click "OK"
    Reason: Gives the OS as much virtual RAM as it needs
  6. Step 5If you have two hard drives installed on your system, move the paging file to the second hard drive:
    a. Follow steps "a" through "g" of Step 4
    b. Make sure the "C" drive is highlighted at the top
    c. Click the "No paging file" option
    d. Click "Set"
    e. Click "OK"
    f. Click "Change"
    g. Make sure the second hard drive is highlighted at the top (The "C" drive shouldn't be the one highlighted. It might be called "D" or "E")
    h. Select the "System managed size" button
    i. Click "Set"
    j. Click "OK"
    k. Click "OK"
    l. Click "OK"
    m. Restart your computer so the changes can take effect
    Reason: Offloads the virtual memory onto the other hard drive, allowing the main hard drive to work faster.
  7. Step 6Disable Hard Disk Indexing:
    b. Right click on the "C" drive
    d. Uncheck the box that says "Allow Indexing Service to index for fast file searching"
    e. Click "OK"
    Reason: Hard drive is accessed less often, making it faster (note this comes with the price of making file searches slower. If you use the search box frequently, you may want to leave this checked. Otherwise, uncheck it.)
  8. Step 7Determine What Version of Internet Explorer You Have:
    a. Open Internet Explorer
    b. Select "Help," and then "About"
    c. The version number is listed under the IE logo. If you have version six, go to Step 8. If you have version seven, go to Step 9.
  9. Step 8Delete Useless Files in IE 6:
    a. Click "OK"
    b. Select "Tools," and then select "Internet Options..."
    c. Click "Delete Cookies"
    d. Click "OK"
    e. Click "Delete Files"
    f. Click "OK"
    g. Click "Settings"
    h. Click "View Files..."
    i. Highlight and delete all the files
    j. Close the window, and click "OK"
    k. Click "Clear History"
    l. Click "Yes"
    m. Click "OK"
    Reason: Time isn't wasted loading old, unwanted files
  10. Step 9Delete Useless Files in IE 7:
    a. Click "OK"
    b. Select "Tools," and then select "Internet Options"
    c. Select "Delete..." under the "Browsing History" section
    d. Click "Delete All"
    e. Click "Yes"
    f. Click "OK"
  11. Step 10Delete Useless Files in Firefox:
    a. Open Firefox
    b. Select "Tools"
    c. Select "Clear Private Data..."
    d. Check Everything but "Offline Website Data" and "Saved Passwords"
    e. Click "Clear Private Data Now"
open software source download from http://digitalpowering.blogspot.com
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Computers & Internet Logo
Diffrence
The terms 32-bit and 64-bit refer to the way a computer's processor (also called a CPU), handles information. The 64-bit version of Windows handles large amounts of random access memory (RAM) more effectively than a 32-bit system. For more details, go to A description of the differences between 32-bit versions of Windows Vista and 64-bit versions of Windows Vista online.
Jul 24, 2009 | Computers & Internet
Won't work with Vista 64 bit
Hello
I am running Windows Vista 64 bit also and finding out that there are a lot of programs that won't run on a 64 bit machine due to the fact they are not supported for 64 bit, listed below is info to your problem,
Photoshop Elements compatibility with Windows Vista This TechNote lists which versions of Adobe Photoshop Elements are compatible with Microsoft Windows Vista.
Photoshop Elements Version Compatible with Windows Vista (32-bit)? 6.0 Yes 5.0 Yes
Note: You must download the Photoshop Elements 5.0.2 update to ensure compatibility with Windows Vista.
4.0 No 3.0 No 2.0 No 1.0 No
Note: For the versions of Photoshop Elements that are compatible with Windows Vista, the 64-bit editions of Vista are not supported. Adobe Technical Support can assist you with the features of Photoshop Elements and with issues that also occur in supported operating systems. Technical Support cannot, however, assist you with issues that occur only on the 64-bit editions of Windows Vista. Instead, you can use the following support options on the Adobe website:
  • The User to User Forums, on which you can enter your problem or concern to see if another Adobe user can offer advice. Access this resource at www.adobeforums.com.
  • The Support Knowledgebase, which contains solutions for issues that occur on supported operating systems. Access this resource at www.adobe.com/support/photoshopelements.
dmg49
Apr 15, 2009 | Adobe Premiere® Elements 3.0 Full Version...
pc slow
There are a number of issues might be affecting your PC's performance, some are dangerous while others not that serious. Learn why how to speed it up easily from: http://www.whyismypcsoslow.net/
Apr 07, 2008 | Lexmark X5470 All-In-One InkJet Printer
209 people viewed this tip
David Payne
David Payne
