Tip & How-To about Cell Phones
Samsung phones
Hello there Samsung slider phones LCD or screen problem. Always you have seen that samsung phone get problem like some phone doesnt have light in LCD and some times they does not turn on. Samsung slider phones like G 600 , U 600 . J 700, E250 ,D800 and D900.Slider phones always has Ribben ( slidr belt ). And this ribben always connect phone upper part ( screen ) to the mother board.when the ribben (slider belt) got damage then it gives you that problem.it happens when you use your phone roughly or when you dropped your phone on concrete or any different floor.Mostly Samsung phone model U600 , G600 AND J700 has this problem.whenever your phone gets this problem firstly check. And Do not try any flashing or any kind of software tools. it easy to change ribben (slider belt ). Just get ribben belt or some tiny screw driver and some slider opener. this tools are easy to get from any tools shop. then mostly phone has screw. firstly open the battery cover and take it out and see two hole under the battery and when you slide up your phone then you can see two screw just under your phone top keypad just hold the slider for while and open those screw and slide up then see two rubber things are both side on camera. Use any flicker type things and take out that rubber top then you can see two screw just under the screw open those screw then use the slider opener if the opener is tight if slider is loose the do not use opener just take it out so softly and remove the one side of the ribben which you can see connected of mother board just take out ribben and put new one ribben the put all things back as a normal then tight the screws and put battery then turn it on your phone will turn on.some phone like U600 ,j600,has touch panel. this type of model slider belt or ribben always comes with touch panel and its quite difficult and quite expensive to change.Samsung U600 has this problem mostly because they are very thin and then slider belt is as well thin and they get this problem so quickly.
thanks
Cell Phones Logo
I have a Samsung Rogue my screen won't turn On but
The connector for the screen is usually a very flimsy peace of material between the main board and the LCD. This comes loose a lot especially on sliders or phones that get dropped etc. The Rogue is probably out of warranty so you can attempt to fix it yourself by taking the phone apart and locating the connector and attempting to reset it.
Mar 28, 2012 | Samsung Cell Phones
Instructions to replace the samsung sgh-a877 lcd screen?
needs major work. Do it at your own risk. Did everything right but messed up and broke the tab on the touchscreen cable connector on my daughter's phone. Feel crappy. Will post with pictures later on.
1. remove battery/ Sim 2. remove all screws from the back on the black plastic cover. (6 of them) Leave the ones below the battery. 3. Use the pry tool to remove the back case. 4. remove the motherboard, three connectors, one on bottom left, antenna and top right below the board. board comes off. You also have to remove the power connector (transparent plastic) to what appears to be some hf component (cylinder). there are two wires (red, black), red goes to side marked +. remove with pry tool. 5. Remove all small screws you can see. 6. Remove the shiny plate, keyboard button layer. 6a. Remove the lcd connector screw and the connector. 7. Remove screws from the bottom of the lcd portion of the slider. You can access all screws from the back side. Use the slider to get the back of the phone. There are 5 screws. 8. Use the pry tool to take out the back slider. Be careful with the lcd connector. 9. pull up the black tab on the digitizer connection from the screen 10. remove the lcd 11. use a hair dryer to loosen the glue around the broken digitizer. 12. put the new one in 13. Put all the screws back.
Apr 10, 2010 | Samsung SGH-A877 Impression Cell Phone
MY SAMSUNG PHONE TURNS OFF AND TURNS BACK ON BUT NOT ALL THE WAY. I NEED HELP!!!! WHAT WRONG WITH IT??
it happens with samsung sliders phone. because sliders phone always connected via only thinn ribben. which is connect the screen and mother board. when the ribben gone damage then samsung phone do thins things that turn on and turn off itself. if your phone is slider samsung G600,U600,J600 and j700 then it could be the ribben problem.
Dec 30, 2009 | Cell Phones
Samsung i450 totally white screen
Hello Sir, A total white screen is seen usually when the phone's software is corrupted by infection ( Virus, etc ). Or the other reason may be that the phone's software version is outdated and needs to be updated. You have to update the software of the phone which will reset all the info of the phone. If you have the PC Suite, try to retrieve back all stored contacts and data and then update. If you are having difficulty in updating or confused, you can freely take it to a Samsung Service center. They will do it instantly.
Thank you Sir, Have a nice day.
Dec 06, 2009 | Samsung SGH-i450 Cellular Phone
how to remove samsung a737 slider?
After spending several hours and a trip to Lowe's for the right screw driver n needed to take the phone apart. I still couldn't figure out how to remove the lcd screen. Therefore, I decided to buy the lcd screen online and I will take my phone to a professional for repair.
Aug 30, 2009 | Samsung SGH-a737 Cellular Phone
243 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
