Tip & How-To about Microsoft Windows XP Professional for PC
Remove BT Voyager 100 Modems drivers with the newdev.dll error
The newdev.dll is something to do with SP3 being installed, however if you try with SP2 you will get the Can't Open Bitmap and still you will be frustrated.
If you have SP2 installed you will recieve the error this is when you use the older newdev.dll (2146). If you install SP3 you will get the error this is with the newest newdev.dll (5512) that SP3 installs
http://rapidshare.com/files/261766010/newdev.dll_error.zip
If you download this file it has both NEWDEV.DLL versions, you will need to restart you PC in safe mode to replace the DLL file then restart, see if you can get it to work I didn't and gave up in the end I even tried the installer for the origonal modem also included all without any luck.
In the end I removedall traces of the driver using the jv16pt v1.0.0.124 FREEWARE version, the 2009 version is about £25 but if you like the free one the latest will impress you as you can remove services and control panel shortcuts.
Hope this helps you I will find another fool proof method soon I believe that if you use doctor100.exe from the AOL CD you can remove the driver however I don't have one so I can't try this at the moment.
30 Trial Version link
http://www.macecraft.com/downloads/jv16pt_setup_hb.exe
After you have installed this trial version it will place a buy me now icon to the desktop I recommend that you do there are many other tools that perform similar functions, CCleaner from Piriform is probably the best freeware alternative that deals with registry and applications but doesn't give you the control of the power tools.
http://download.piriform.com/ccsetup227.exe
It is also available for the U3 stick drives now at the suppliers website so you don't have to create your own I use this loads on PC's that I fix to remove all the **** in the cache, cookie and almost all temp files that clog up your regsitry.
http://www.ccleaner.com/download/builds/downloadbinu3file
Microsoft Windows XP Professional for PC Logo
skype kernel32
Skype v6.6.0.106 is the last version which supports XP SP2. If you try install newer version, you will need SP3 installed, or you will get the kernel32 problem "Failed to get proc adress for getLogicalProcessorInformation (KERNEL32.Dll)".
If you don't want to install SP3 for your XP, here is a work around for you to run Skype with XP SP2.
1. Download Skypesetupfull.exe v6.3.30.105;
2. Uninstall your current version of Skype from Control Panel;
3. Block the website download.skype.com in your router or in the
Host file;
4. Delete any auto downloaded skypesetup.msi in %Temp%
folder;
5. Install Skype v6.3.30.105.
Done.
Aug 04, 2013 | Microsoft Windows XP Professional SP2
Microsoft updates do not install
You have not said which OS you are using so; from http://support.microsoft.com/kb/943144
When you try to install Windows updates from the Windows Update Web site, the Microsoft Update Web site, or by using Automatic Update, you receive a message that the update is not installed successfully. Additionally, the update is not displayed in the update history.
You may experience this issue in the following scenarios:
Scenario 1 You try to install updates after repair a Windows XP installation by using the Windows XP CD.
Scenario 2 You perform the following operations before you try to install Windows updates:
You perform a new installation of Windows XP Service Pack 2 (SP2).
You visit the Windows Update Web site, or the Microsoft Update Web site.
Note When you visit the update Web site, the latest version of Windows Update software will be installed in your computer.
You install Windows XP Service Pack (SP3) without a restart.
You try to install Windows updates after the install of Windows XP SP3.
Then cause ;
This issue occurs because the Wups2.dll file that is included in the latest version of Windows Update is not installed correctly.
For scenario 1, the registry entries that correspond to the Wups2.dll file are missing after the repair install of Windows XP. The release version of Windows XP does not contain the Windows Update software.
For scenario 2, the registry entries that correspond to Windows Update are changed back to the Windows XP SP2 version if you did not restart the computer before you install Windows XP SP3. The registry entries for the Wups2.dll file are changed to pointing to the Wups.dll file that is included in the release version of Windows XP SP2.
To resolve this problem, use one of the following methods;
Method 1: Download and install the Windows Update Agent,
For an x86-based computer; http://download.windowsupdate.com/WindowsUpdate/redist/standalone/7.4.7600.226/WindowsUpdateAgent30-x86.exe
For an x64-based computer http://download.windowsupdate.com/WindowsUpdate/redist/standalone/7.4.7600.226/WindowsUpdateAgent30-x64.exe
Method 2: Register the Wups2.dll file,
To have MS register the Wups2.dll file in Windows for you, go to http://support.microsoft.com/kb/943144#FixItForMeAlways.
If you prefer to fix this problem yourself,
To register the Wups2.dll file in Windows, follow these steps:
1. Stop the Automatic Updates service. To do this, follow these steps:
a. Open the Command Prompt window. To do this, click Start, click Run, type cmd, and then click OK.
b. At the command prompt, type the following command, and then press ENTER:
net stop wuauserv
2. Register the Wups2.dll file. To do this, follow these steps:
a. At the command prompt, type the following command, and then press ENTER:
regsvr32 %windir%\system32\wups2.dll
Note For a computer that is running Windows XP Professional x64 Edition, type the following command, and then press ENTER:
regsvr32 %windir%\syswow64\wups2.dll
b. Click OK if you receive a verification message.
3. Start the Automatic Updates service. To do this, type the following command at the command prompt, and then press ENTER:
net start wuauserv
4. Exit the Command Prompt window. To do this, type exit at the command prompt, and then press ENTER.
Jun 02, 2011 | Microsoft Computers & Internet
what does "RUNDLL Error loading newdev.dll" and
newdev.dll is the Windows file that is responsible with the recognition of the hardware and the loading of the drivers - an absolutely critical file. This file is severely corrupted and the only way to fix that is to perform a Repair install.
Dec 15, 2010 | Dell Computer Refurbished OPTIPLEX SX270...
i am trying to install usb driver for zxdsl 831 aii modem but setup gives the message that unable to find newdev.dll
"This application failed to start because newdev.dll was not found. Re-installing the application may fix this problem."
Jul 18, 2009 | Computers & Internet
newdev.dll error and asking for admin rights on bt modem 105
If you have IE-8 installed, then uninstall it and it will start working.
You can uninstall IE-8 using this command in the run dialog box:
"C:\WINDOWS\ie8\spuninst\spuninst.exe
Regards,
Ashish
Jun 20, 2009 | Computers & Internet
1,066 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
