Tip & How-To about Computers & Internet
How to install memory card
Make sure the card is compatible by checking the ddr 1 or 2 or model number of the computer and go to best buy or www.newegg.com to buy memory cards make sure the computer is powered down and unplugged before installing and u have the right slot available and slide the side off and detach the hooks and open them or open them and slide the card in. make sure is like the other card and has same number of pins.
Computers & Internet Logo
Will a DDR3 graphic card work as it should work on a DDR2 motherboard or ram
Add more RAM
If you're not sure if a module is right for your system, use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules.
First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system.
You should always ask for a guarantee on the compatibilitybefore making any purchase and try to buy for working pairs if possible.
computer users often get confused when assembling or upgrading their first computer. While the most common error is made when distinguishing system memory, RAM, from hard drive space, gaming computers have an extra wrinkle to worry about.
Graphics cards use memory separately from the system memory mounted on the motherboard. Some graphics cards use the more typical DDR standard, though it's permanently attached to the graphics card circuitboard, while others use the new GDDR standard.
For the most part, the internals of the graphics card aren't relevant to the rest of the computer it's all about the connection slot.What Is DDR Memory?
DDR, or "Double Data Rate," is the standardized random access memory format for most desktop and laptop computers.
DDR RAM comes in different generational standards: DDR, DDR2, DDR3 and the newer DDR4.
RAM chips, known as DIMMs, come in only one format, as do the DIMM slots on motherboards, so a DDR3-compatible motherboard memory slot can accept only DDR3 RAM DIMMs RAM that uses an earlier or later standard is incompatible.
GDDR Memory and Graphics Cards
Modern graphics cards use a modified memory standard called GDDR, short for Graphics Double Data Rate. While similar, GDDR and DDR memory is not the same:
Most importantly, GDDR memory is integrated into the graphics card and cannot be removed. Some older graphics cards use DDR, DDR2 and DDR3 memory, but this is also integrated into the card.
Graphics cards of varying power come with different kinds of RAM as of the date of publication, most cards feature GDDR4 or GDDR5 memory
Graphics Card Motherboard Connections
Discrete desktop graphics cards are mounted inside a computer case and plugged directly into the motherboard.
Three standard connections are used for graphics cards: PCI-Express (the most common and powerful), PCI and AGP.
It is this connection that determines how much data can be shared between the graphics card and the other system components, such as the CPU, the system RAM and the hard drive.
The expansion slot standard is the primary function for determining whether or not a graphics card is compatible with any given computer:
If your motherboard has a PCI-E slot, it's compatible, if not ideally so, with all PCI-E graphics cards.
Graphics Card Memory and System Memory Compatability
Memory is an important part of game performance, but graphics memory and system memory are two different things.
For better performance, it's best to have as much graphics memory AND system memory as possible, but the different standards used by the graphics card and the motherboard are largely irrelevant.
As long as the graphics card uses the correct expansion slot standard, it will work with the corresponding motherboard, regardless of its DDR version.
Mar 10, 2014 | IBM Lenovo ThinkCentre M55e PC Desktop
what is compatible with my emahcines w3050 in upgrading my video memory. What limits are on my machine?
HDMI? Oh, then you would be talking about a graphics card like this one,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5071689&CatId=318
HIS Radeon HD4670 IceQ
1) AGP 8X graphics card
2) Has a VGA, DVI, and HDMI port
3) 1GB of GDDR3 ram memory
4) 128bit interface
5) 320 Stream Processors
6) Core Clock is 750MHz at maximum capability
7) Memory Clock is 1746MHZ at maximum capability
It doesn't matter that your computer system ram memory is DDR Sdram. The GDDR3 graphics ram memory operates independent of the system ram memory.
Information about graphics, graphics cards, and graphics card terminology,
A) http://www.brighthub.com/video-games/pc/articles/984.aspx
B) http://computer.howstuffworks.com/graphics-card.htm
Mar 20, 2010 | E-Machines W3050 PC Desktop
what memory stick and graphic cards to get
Your motherboard has 3 PCI slots. Any card you install can only be a regular PCI card.
The RAM in your motherboard has to be DDR (333 or 400) 184 pin DIMM's.
Here is a link for your motherboard manual:
Asus P5P800-MX Manual
Layout pic is on page 1-7. Info on your memory is on page 1-15.
Thanks for using Fixya.
May 10, 2009 | ASUS P5P800-MX Motherboard
question
First, you will not be able to upgrade the video card on your laptop, since video cards for laptops are specifically designed to fit onto the motherboard and the design of the laptops body.
Secondly, sound cards as well are also deisgined that way, some sound cards on laptops are built in to the mother board and higher end sound card for laptops are specifically designed to fit onto the motherboard and the laptop's body.
Hard Drives on the other hand can be upgraded to a higher capacity but you can't add an additional Hard Drive. I have checked the specs of your laptop has 80GB IDE. You can upgrade to 120GB IDE or higher if you like. Just make sure that you purchase a 2.5" HDD (5400RPM/7200RPM speeds).
Here are examples of Hard drivers that you need for upgrade. I checked newegg.com for available laptop hard drive. You can check other online stores or other computer shops near you if you as well.
links (Hard Drive) :
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136130
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148073
http://www.newegg.com/Product/Product.aspx?Item=N82E16822146200
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136114
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148130
**Since you have installed Windows Vista, I suggest that you upgrade the RAM (Memory) on the laptop for smooth performance for Windows Vista. The maximum memory on your laptop is 2GB DDR SDRAM. Buyin RAM for laptops are a little but tricky so you can just go to the link below for specific memory upgrade for your laptop (I suggest that you purchase 2 pcs of 1GB since your system can accomodate up to 2GB).
Link for RAM (Memory) :
http://www.edgetechcorp.com/memory/upgrade.asp?cid=29695
**If you decied to upgrade the Hard Drive, you can still use you old Hard Drive as an USB external Hard drive for storage purposes. You will just have to purchase a 2.5" External Hard Drive Enclosure. Click on the link below for the example of the product :
http://www.newegg.com/Product/Product.aspx?Item=N82E16817145136
http://www.newegg.com/Product/Product.aspx?Item=N82E16817145329
**If you can't click on the links, just copy the link and paste it to your's browser's address bar.
Oct 28, 2008 | Sony VAIO PCG-GRT360ZG Notebook
graphics card upgrade
Not compatable at all.
DDR SDRAM memory uses 184 Pin Dimms
Double-Data-Rate Synchronous Dynamic Random Access Memory, better known as DDR SDRAM or DDR RAM for short, is a type of very fast computer memory. DDR RAM is based on the same architecture as SDRAM, but utilizes the clock signal differently to transfer twice the data in the same amount of time.
DDR2 SDRAM uses 240 Pin Dimms.
DDR2 SDRAM improves on DDR SDRAM by using differential signaling and lower voltages to support significant performance advantages over DDR SDRAM.
If your question has to do with buying a video card that is going to use DDR2 ram, that would be a faster graphics card. You can also get video cards with DDR3 ram which again is even faster.
Oddly enough in respect to system memory DDR2 is supposed to be faster than DDR yet the DDR memory cost more than the DDR2. Go figure.
Click the link for video cards.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&
http://www.google.com/search?hl=en&q=XFX+AGP+8x+512MB+DDR2+video+card&btnG=Search
Need help with anything, feel free & ask.
Have a great weekend!
Mike
Mar 21, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
139 people viewed this tip
David Payne
David Payne
