Tip & How-To about Microsoft Windows XP Professional for PC
How do I perform an umattended install of WinXP without an A: drive ?
This is very simple when you have created your winnt.sif file to your specification instead of copying it to a floppy disc add it to the I386 folder and use Nero as normal.
Microsoft Windows XP Professional for PC Logo
I want to do a clean install of Winodws XP sp3 on a Acer 5515 laptop computer. What are the instructions I need to follow to have this done by me?
The best way is to use the factory reset option this will revert you laptop back to the way it was before you started using it.
I think is ALT + F10 during the bootup process.
If this fails I recommend that you use a Windows XP boot CD with SP3 slipstreamed, you can use nLite to do this, if you use have a USB floppy drive you can use a winnt.sif file on it you can add your OEM licence if you dont have a floppy then you can add this file to your I386 folder and burn a new install CD.
Use Nero Boot CD menu option and make sure that you set the screen as per this screen dump otherwise it wont work. Use Mode 2/XA for maximum CD-drive compatibility.
Download the required boot image file HERE
Minimum Required for Windows XP SP3 copy and paste this into a file named winnt.sif, replace the xxxx-xxxx-xxxx-xxxx with your valid Licence key I suggest that you check it first HERE fill in the rest your self and save it. You can add much more to this SIF file search the internet for more HERE is a great link for you to start with
[Data]
MsDosInitiated=0
UnattendedInstall="Yes"
[Unattended]
UnattendMode=ProvideDefault
[UserData]
ProductKey="XXXXX-XXXXX-XXXXX-XXXXX-XXXXX"
FullName="Your Name Her"
OrgName="Your Company Here"
ComputerName="What ever you want Here"
[Display]
BitsPerPel=32
Xresolution=1024
YResolution=768
Vrefresh=60
Hope this helps please rate.
Nov 11, 2009 | Microsoft Windows XP Home Edition
292 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
