Tip & How-To about Dishwashers
Is Your Dishwasher Leaving Your Dishes Dirty? We Can Help!
Empty out all the dishes. Add a box of Dishwasher Magic (or a full cup of powdered TANG Orange Juice) in the bottom of the dishwasher. Run dishwasher through a complete cycle.
The acid in the products eat up all the grime and small food particles that deposit in the spray arms and in the pipes that supply the water to your dishes.
Contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST for all your appliance repair questions or to purchase appliance parts, accessories or supplies.
Just provide us with your brand and model number and we look forward to working with you to get your appliances back in tip top shape.
Happy New Year to You All! Thanks, Ella
Dishwashers Logo
I want to take off the bottom screen to clean debris. I have taken screws out, how do I remove the screen?
You may to remove more screws from around the complete bottom part of your dishwasher. Have you tried to add Dishwasher Magic to clean the grit and grime out first? Or perhaps if you can't find Dishwasher Magic, we started using Tang Orange Juice powder before the days of the modern prodcuts. The citrus in the powder eats all the tiny food particles away.
In either case, empty all the dishes from the inside, add a cup of Tand or follow the instruction on the box of DW Magic. Run your d/w through a complete cycle.
This should clean your dishwasher out.
Hope this solves your problem.
You may contact us at;
with any questions or comments. Thanks, Ella
Nov 13, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
have a maytag mdb6100 how do i get accsess to take lower wash arm out i want to clean
You have to remove the screws in the bottom filter where the spray arm is. Before you do that, you can put a cup of Tang Orange Juice Powder in the unit without any dishes and it will clean it out unless it has plastic or glass pieces in it. Or you can use Dishwasher Magic. We have parts and supplies if you'd like to call us. Hope this works out well for you! Ella
Aug 26, 2009 | Dishwashers
Dishes will not get clean and rinsed...
You may just have hard water in your area. Has there been a drought where you live? If so, don't be frustrated any longer, that's it. Jusyt add some Dishwasher Magic (or one cup of Tang dry orange juice) to an empty unit and run through the whole cycle. This should help. Hope this helps and I hope your frustration is gone. :)
top rack washer arm isn't spinning and therefore not cleaning dishes in top rack, bottom works fine
You can replace the whole top assembly. And before you run the cycles again, try putting a cup of Tang (dry) orange juice through the cycle without any dishes or get some Dishwasher Magic and you'll have a sparkling new dishwasher once again! hope this helps you!
Aug 14, 2009 | Dishwashers
162 people viewed this tip
Top Dishwashers Experts
Owen Barnes
